[Ovmsdev] Fwd: [ovms:2087] Consult on Renault twizy
Wed Sep 19 16:13:40 HKT 2018
It's still the V2 user guide I meant. I need to find time to make a V3 version. As features, commands and configs are very similar, the V2 guide is still valid.
I added some basic info on the differences to my FAQ:
https://dexters-web.de/faq/en#usermanual
Am 19.09.18 um 10:03 schrieb Mark Webb-Johnson:
> Thanks. That makes sense (I was looking in vehicle_twizy folder, and app sources).
> You mention a twizy user guide? Do you have a link for that, so I can add it to the website?
> Regards, Mark
>> On 19 Sep 2018, at 3:59 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> For the record:
>>> In order to send commands to the Twizy, you need to enable CAN write access.
>>> You can do so either by using the web UI or by setting feature 15 to 1 or by issuing "config set xrt canwrite yes".
>> @Mark: the error text is defined here:
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/canopen/src/canopen.cpp#L373
>> Am 19.09.18 um 04:09 schrieb Mark Webb-Johnson:
>>> @michael,
>>> Could you help this user? I greped for the error text in OVMS v2, v3 and Android, source code, but can’t find it.
>>> <Screenshot_20180918-222459.png>
>>>> Begin forwarded message:
>>>> bricoauto has created the ticket 'Consult on Renault twizy':
>>>> https://www.openvehicles.com/node/2087#comment-0
>>>> State: new
>>>> Priority: normal
>>>> You can visit the following URL to update this ticket:
>>>> https://www.openvehicles.com/node/2087#comment-form
>>>> Ticket text:
>>>> I have successfully installed the Ovms 3.1 module in my renault twizy, but I
>>>> still do not know how to modify parameters. For example with the App, if I
>>>> want to modify the speed limitation, it tells me the following error message:
>>>> Can bus not in active mode
>>>> I guess that writing or reading by can not be active, because I can not see
>>>> the fault logs etc ...
>>>> Could you help me with this?
>>>> Regards!
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180919/83017c20/attachment-0001.html>
