[Ovmsdev] Fwd: [ovms:2087] Consult on Renault twizy
Wed Sep 19 15:59:15 HKT 2018
For the record:
> In order to send commands to the Twizy, you need to enable CAN write access.
> You can do so either by using the web UI or by setting feature 15 to 1 or by issuing "config set xrt canwrite yes".
@Mark: the error text is defined here:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/blob/master/vehicle/OVMS.V3/components/canopen/src/canopen.cpp#L373
Am 19.09.18 um 04:09 schrieb Mark Webb-Johnson:
> @michael,
> Could you help this user? I greped for the error text in OVMS v2, v3 and Android, source code, but can’t find it.
>> Begin forwarded message:
>> bricoauto has created the ticket 'Consult on Renault twizy':
>> https://www.openvehicles.com/node/2087#comment-0
>> State: new
>> Priority: normal
>> You can visit the following URL to update this ticket:
>> https://www.openvehicles.com/node/2087#comment-form
>> Ticket text:
>> I have successfully installed the Ovms 3.1 module in my renault twizy, but I
>> still do not know how to modify parameters. For example with the App, if I
>> want to modify the speed limitation, it tells me the following error message:
>> Can bus not in active mode
>> I guess that writing or reading by can not be active, because I can not see
>> the fault logs etc ...
>> Could you help me with this?
>> Regards!
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180919/72135c3d/attachment-0001.html>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180919/72135c3d/attachment-0001.png>
