[Ovmsdev] 3.1.006
Wed May 23 14:32:06 HKT 2018
Michael,
A good time to do this.
I have updated mine (git pull; git submodule update) and it went cleanly. There are some new/changed kconfig values so we will need to revise the support/sdkconfig* files, and I will handle that tonight/tomorrow.
> On 23 May 2018, at 5:16 AM, Michael Balzer <dexter at expeedo.de> wrote:
> I've pushed the updated esp-idf status to our clone now, so we can start using that for release 007.
> I've also checked the upstream master status again, which is already quite some commits ahead, including lots of wifi and bluetooth updates.
> Unfortunately I got IRAM space issues and had to disable bluetooth to be able to build at all. The resulting firmware crashed immediately on wifi power up with
> error code 0x102 and a message that we should use WIFI_INIT_CONFIG_DEFAULT. Which we do, I don't see anything wrong in our init code. So I switched back to the
> working version for now.
> To use the new esp-idf version all you need to do is a pull from our repository and a git submodule update. The xtensa tools are still the same.
> Am 17.05.2018 um 10:41 schrieb Michael Balzer:
>> Regarding the esp-idf update: it works without (new) issues and seems to improve stability a bit, but not as much as I was hoping.
>> So it's an option, but not a priority for 006.
>> Am 17.05.2018 um 05:06 schrieb Mark Webb-Johnson:
>>> Deadline for the factory firmware is this weekend. The modules have all been built and are waiting sim cards, firmware flash, then final QC.
>>> So, I suggest we freeze things as they are. I will double-check the wifi setup tonight (it seemed ok last time I checked, so hopefully good now). Build will not include the bluetooth code I am working on (that is disabled in our default sdkconfig anyway).
>>> Is there anything else holding this up? Or anything anybody wants to rush in?
