[Ovmsdev] wifi not coming all the way up?
Julien “JaXX” Banchet jaxx at jaxx.org
Mon Mar 19 21:01:19 HKT 2018
Oh!? A wrong CAN speed ? Haven’t though of that.
I have RT set, but I do’t know how to look up the speed which is set (besides the defaulted CONFIG_CAN_SPEED_100KBPS=y in sdkconfig, though I suppose the module sets the right speed, right ?)
JB./.
On 19 Mar 2018 at 13:39 +0100, Mark Webb-Johnson <mark at webb-johnson.net>, wrote:
> Do you have a vehicle module defined, with a can bus active?
> I had a similar thing when I was set to 1Mbps (it should have been 500Kbps).
> > On 19 Mar 2018, at 7:46 PM, Julien “JaXX” Banchet <jaxx at jaxx.org> wrote:
> > It went christmas animation nuts as soon as I plugged it on the bus (already contact ON+GO), and went away the second I unplugged it.
> > I admit having left the v2 (which still carries all my profiles, and in case I needed to limit power+recup on the way as it’s been snowing again)
> > My bet is that there where too many CAN terminations on the bus and the dashboard cluster couldn’t see it’s friends, I’ll give it a shot without v2 on my way back home.
> > (Which leads me to believe the termination resistor on my Arduino OBD shields aren’t connected)
> > JB./.
> > On 19 Mar 2018 at 12:43 +0100, Michael Balzer <dexter at expeedo.de>, wrote:
> > > Uh oh… CAN bus contact failure? I haven't had any issues like that…
> > > Am 19.03.2018 um 11:09 schrieb Julien “JaXX” Banchet:
> > > > That didn’t happen :-)
> > > > https://twitter.com/happyjaxx/status/975675071451844608
> > > > On 19 Mar 2018 at 10:07 +0100, Julien “JaXX” Banchet <jaxx at jaxx.org>, wrote:
> > > > > Gonna put it in the car (despite the passive GPS issue)
> > > > _______________________________________________
> > > > OvmsDev mailing list
> > > > OvmsDev at lists.teslaclub.hk
> > > > http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
> > > Michael Balzer * Helkenberger Weg 9 * D-58256 Ennepetal
> > > Fon 02333 / 833 5735 * Handy 0176 / 206 989 26
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180319/ddc96f2e/attachment.htm>
