[Ovmsdev] wifi not coming all the way up?
Mon Mar 19 20:39:23 HKT 2018
Do you have a vehicle module defined, with a can bus active?
I had a similar thing when I was set to 1Mbps (it should have been 500Kbps).
> On 19 Mar 2018, at 7:46 PM, Julien “JaXX” Banchet <jaxx at jaxx.org> wrote:
> It went christmas animation nuts as soon as I plugged it on the bus (already contact ON+GO), and went away the second I unplugged it.
> I admit having left the v2 (which still carries all my profiles, and in case I needed to limit power+recup on the way as it’s been snowing again)
> My bet is that there where too many CAN terminations on the bus and the dashboard cluster couldn’t see it’s friends, I’ll give it a shot without v2 on my way back home.
> (Which leads me to believe the termination resistor on my Arduino OBD shields aren’t connected)
> JB./.
> On 19 Mar 2018 at 12:43 +0100, Michael Balzer <dexter at expeedo.de>, wrote:
>> Uh oh… CAN bus contact failure? I haven't had any issues like that…
>> Am 19.03.2018 um 11:09 schrieb Julien “JaXX” Banchet:
>>> That didn’t happen :-)
>>> https://twitter.com/happyjaxx/status/975675071451844608 <https://twitter.com/happyjaxx/status/975675071451844608>
>>> On 19 Mar 2018 at 10:07 +0100, Julien “JaXX” Banchet <jaxx at jaxx.org> <mailto:jaxx at jaxx.org>, wrote:
>>>> Gonna put it in the car (despite the passive GPS issue)
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180319/931c8c2c/attachment.htm>
