Tom Parker
tom at carrott.org
Sun Mar 18 18:05:12 HKT 2018
On 16/03/18 14:48, Mark Webb-Johnson wrote:
> Probably the most useful output, at the time when the modem couldn’t
> recover would be:
> simcom status
> network status
> module memory
> module tasks
> I’m only running with the DEMO vehicle module, Server V2, Wifi AP, and
> SIMCOM. No GPS enabled. The network seems stable to me (although I am
> getting one general crash about once a day).
I'm running the Leaf module, server v2, no wifi, simcom and no gps.
The first 3 of the attached logs record what happened yesterday and this
morning with code from ee023a5 from a few days ago:
ovms_2018-03-17T04_28_21+0000.log.bz2: Driving 10km and into an
underground carpark where the OVMS lost signal. Interestingly my cell
phone (on a different carrier who still have a 2G network) maintained a
connection but degraded to 2G and then stayed on 2G for an hour or so
afterwards even though I went back back to the surface.
ovms_2018-03-17T08_38_49+0000.log.bz2: 4 hours later, driving out of the
carpark and returning to the starting point. Connection to the v2 server
was not restored.
ovms_2018-03-17T23_01_38+0000.log.bz2: 12 hours later, running your
recommended commands. I note that 13 hours before the OVMS was still
talking to the simcom but in this session it was no longer talking. When
I tried to power off the simcom, the OVMS hung and I had to reset it
with the button.
You will see in the logs that I switched back to the Spark network using
an m2m simcard after resetting with the button. I worked out why the
signal strength is so poor here -- Spark's network is on 850/2100MHz
while I have a SIM5360E module which I think is a 900/2100MHz modem.
According to internet sources, Spark only have 2100MHz infill with the
main network running on 850MHz, so that probably explains why it works
in some locations and not others.
With current master running in the OVMS and using the m2m console, I
disabled the simcard, and pretty much immediately you can see the
disconnection in the ovms logs. However when I activate the simcard, it
does not reconnect. If I press the button to reboot the module it does
reconnect. In this log file, 445227 is after I reactivated the simcard
(I actually reactivated it some time before then). Doing a "power simcom
off", followed by a "power simcom on" seems to have fixed it. I don't
know if the power cycle is required to reactivate the simcard or if it
merely speeds up the activation? ovms_2018-03-18T09:25:41+00:00.log.bz2
is a transcript of this session.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180318/275df725/attachment.htm>
Type: application/x-bzip
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180318/275df725/attachment-0008.bin>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180318/275df725/attachment-0009.bin>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180318/275df725/attachment-0010.bin>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180318/275df725/attachment-0011.bin>
