[Ovmsdev] MQTT and Ovms Server v3
Tue Jul 10 14:42:19 HKT 2018
I’ve just pushed the support for notifications in OVMS Server v3.
With that, the server v3 is functionally complete (at least on the car side). We can:
Connect/disconnect
Handle lists of apps connecting/disconnecting
Send metrics
Send events
Send notifications (including info, error, alert, and historical data)
Receive commands, run them, and return the results
I’m still struggling against drupal authentication at the server side; once that is done we can open this up to wider testing.
Overall, I’m pretty happy with it. We need SSL/TLS support, but at least functionally now it works and is complete.
> On 6 Jul 2018, at 4:16 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>>> I suppose the following topic names:
>>>> metrics:       <prefix>/metric/#
>>>> events:        <prefix>/event/#
>>>> notifications: <prefix>/notify/#
>>>> config:        <prefix>/config/#
>>>> logs:          <prefix>/log/<tag>
>>>> active:        <prefix>/client/<clientid>/active
>>>> requests:      <prefix>/client/<clientid>/request/#
>>>> commands:      <prefix>/client/<clientid>/command/<command id>
>>>> cmd responses: <prefix>/client/<clientid>/response/<command id>
>>> All ok. I am fine with this, and looks clean. I will make the changes today, as I want to get this into some cars asap so we can get a feel for how it behaves.
> Ok. Now implemented, and tested:
> <prefix>/metric/#
> I don’t think config, logs, and requests are critical or urgent. So, I will try to finish events tonight (as that is relatively simple). Notifications over the weekend (more tricky, especially for historical data). It can go in my car with tonight’s nightly ota, for real world testing.
> I’m still trying to get the authentication working for drupal vs mosquitto. Once that is done, I can open up api.openvehicles.com <http://api.openvehicles.com/> MQTT for public use. If I can’t get it done within the next couple of days, I’ll try another broker (lua scripting, anyone?).
> P.S. Commands over MQTT are pretty cool:
> <PastedGraphic-2.tiff>
> <PastedGraphic-3.tiff>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180710/6b5cbf7e/attachment.html>
