[Ovmsdev] OVMS v3.0 modem active antenna modification:
Sat Jan 20 18:06:31 HKT 2018
I’ve asked. Not sure if they are ready yet, but I’ll know next week.
> On 19 Jan 2018, at 6:16 PM, Tom Parker <tom at carrott.org> wrote:
> On 12/01/18 15:35, Mark Webb-Johnson wrote:
>> Here is the modification for active GPS antenna on OVMS v3.0 modems.
>> I’m having a bunch made up pre-soldered and pre-tinned, so just need to be soldered at two points. I will send those out by post when I get them.
> Nice!
> Would it be too much to ask for a case, if you have those? If not I can 3d print one when you get round to publishing the STL.
> Thank you for all the work you're doing!
