[Ovmsdev] OVMS v3.0 modem active antenna modification:
Tom Parker
tom at carrott.org
Fri Jan 19 18:16:52 HKT 2018
On 12/01/18 15:35, Mark Webb-Johnson wrote:
> Here is the modification for active GPS antenna on OVMS v3.0 modems.
> I’m having a bunch made up pre-soldered and pre-tinned, so just need
> to be soldered at two points. I will send those out by post when I get
> them.
Nice!
Would it be too much to ask for a case, if you have those? If not I can
3d print one when you get round to publishing the STL.
Thank you for all the work you're doing!
