[Ovmsdev] Awfully quiet out there
Mon Feb 12 14:46:52 HKT 2018
Steve,
I’m seeing weird heap corruption when I do PSRAM enabled builds and have heap debugging enabled. When I turn off the heap debugging, everything runs fine.
I notice this:
https://github.com/espressif/esp-idf/issues/1582 <https://github.com/espressif/esp-idf/issues/1582>
and some associated fixes by Espressif to master.
Any issues with us merging in upstream Espress ESP IDF master to our clone? See if that resolves the problem?
> On 12 Feb 2018, at 2:15 AM, Stephen Casner <casner at acm.org> wrote:
> It's been several days since I've seen any messages on this list. I
> suppose that Mark has been occupied by the hardware changes. Myself,
> I've finished the things I was working on (with the possible exception
> of adding an immediate-send option back into Mongoose), but I've
> entered a PR to get the code I added to esp-idf to support the
> per-task heap allocation commands accepted into the mainline and have
> been refining the code in response to change requests.
> -- Steve
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180212/9b8c7a33/attachment.htm>
