[Ovmsdev] Awfully quiet out there
    Stephen Casner
    casner at acm.org
    Mon Feb 12 15:02:02 HKT 2018
Mark,
I think the merge you propose should work.  As I mentioned, I'm in
discussion with @projectgus to get my code merged into the mainline.
On Mon, 12 Feb 2018, Mark Webb-Johnson wrote:
> Steve,
> I’m seeing weird heap corruption when I do PSRAM enabled builds and have heap debugging enabled. When I turn off the heap debugging, everything runs fine.
> I notice this:
> https://github.com/espressif/esp-idf/issues/1582 <https://github.com/espressif/esp-idf/issues/1582>
> and some associated fixes by Espressif to master.
> Any issues with us merging in upstream Espress ESP IDF master to our clone? See if that resolves the problem?
> > On 12 Feb 2018, at 2:15 AM, Stephen Casner <casner at acm.org> wrote:
> > It's been several days since I've seen any messages on this list.  I
> > suppose that Mark has been occupied by the hardware changes.  Myself,
> > I've finished the things I was working on (with the possible exception
> > of adding an immediate-send option back into Mongoose), but I've
> > entered a PR to get the code I added to esp-idf to support the
> > per-task heap allocation commands accepted into the mainline and have
> > been refining the code in response to change requests.
> >                                                        -- Steve
> > OvmsDev mailing list
> > OvmsDev at lists.teslaclub.hk
