[Ovmsdev] Crash / reboot loop with log level Info
    Greg D.
    gregd2350 at gmail.com
    Mon Feb 26 13:08:47 HKT 2018
Ha, yes.  Sorry.  I bumped it up to 6144 (seems like a popular value),
and that fixed it.
So, two questions:
1.  What should a proper value be?  I used 6144 only because I'd seen it
used elsewhere.
2.  Shall I push this for permanence?
Thanks,
Greg
Stephen Casner wrote:
> Greg,
> It sounds to me like you are conflating stack overflow with running
> out of heap space.  You are not having a problem (yet) of running out
> of heap space, you have a stack size that is configured too small for
> your program's requirements.  From what I saw in your earlier message,
> you need to change the creation of the Housekeeping task to specify a
> larger stack.
> On Sun, 25 Feb 2018, Greg D. wrote:
>> Hi Steve,
>> I don't see any evidence that there is a recursive loop here, just the
>> buffers stacking up, causing the overflow.  Odd, though, this used to
>> work.  Not sure what else changed at that time besides the logging
>> level; if I recall, it was part of a larger update.
>> But given that we have a RAM fix coming, is it worth messing with this?
>> Greg
>>> Greg,
>>> Unless there is a bug causing infinite recursion or something, you may
>>> have sufficient free RAM to allow increasing the size of the stack for
>>> the task that is getting the stack overflow and achieve successful
>>> operation.
>>>                                                         -- Steve
