[Ovmsdev] /store gone
Sat Feb 17 10:44:49 HKT 2018
Well, Greg, it looks like your /store is scrogged and needs to be
initialized anew.  No idea how that happened.
If by chance you saved a copy of your files using scp then you could
scp the copy back, again assuming CONFIG_OVMS_DEV_CONFIGVFS=y.
On Fri, 16 Feb 2018, Greg D. wrote:
> Hi Steve,
> No, it's just "cannot be opened:"
> OVMS > vfs ls /store
> <snip 124 lines>
> ovms_config
> OVMS > vfs cat /store/ovms_config
> Error: VFS file cannot be opened
> OVMS > vfs stat /store/ovms_config
> OVMS >
> I just noticed that there are 128 lines of bogus files (power of 2 a
> coincidence?), prior to ovms_config.
> Greg
> Stephen Casner wrote:
> > Greg,
> >> But, if I try to vfs cat the file, ovms complains that the file
> >> cannot be opened.
> > Just checking... Is the complaint "Error: protected path"?  If so, you
> > have to set:
> > in sdkconfig to allow access with the vfs commands.
> >                                                         -- Steve
