[Ovmsdev] /store gone
Sat Feb 17 10:50:21 HKT 2018
I have some of the files saved, but there's not a whole lot of
configuring to do in any case.  Not a big deal to re-initialize.
Probably good to do that, just in case there's some old cruft out there
that I don't remember.
Unless someone has any ideas on what might have caused this, I probably
should re-init Flash and move on.  I've not tried to create any files or
such, to not protect the guilty by destroying evidence.  Last chance... ?
So, if we do come to that, what is the easiest way to re-init Flash?
Buttons somewhere, if I recall, but I've never done that as yet.
Thanks,
Greg
Stephen Casner wrote:
> Well, Greg, it looks like your /store is scrogged and needs to be
> initialized anew.  No idea how that happened.
> If by chance you saved a copy of your files using scp then you could
> scp the copy back, again assuming CONFIG_OVMS_DEV_CONFIGVFS=y.
> On Fri, 16 Feb 2018, Greg D. wrote:
>> Hi Steve,
>> No, it's just "cannot be opened:"
>> OVMS > vfs ls /store
>> <snip 124 lines>
>> ovms_config
>> OVMS > vfs cat /store/ovms_config
>> Error: VFS file cannot be opened
>> OVMS > vfs stat /store/ovms_config
>> OVMS >
>> I just noticed that there are 128 lines of bogus files (power of 2 a
>> coincidence?), prior to ovms_config.
>> Greg
>>> Greg,
>>>> But, if I try to vfs cat the file, ovms complains that the file
>>>> cannot be opened.
>>> Just checking... Is the complaint "Error: protected path"?  If so, you
>>> have to set:
>>> in sdkconfig to allow access with the vfs commands.
>>>                                                         -- Steve
