[Ovmsdev] /store gone
Sat Feb 17 10:32:00 HKT 2018
Hi Steve,
No, it's just "cannot be opened:"
OVMS > vfs ls /store
<snip 124 lines>
ovms_config
OVMS > vfs cat /store/ovms_config
Error: VFS file cannot be opened
OVMS > vfs stat /store/ovms_config
OVMS >
I just noticed that there are 128 lines of bogus files (power of 2 a
coincidence?), prior to ovms_config.
Greg
Stephen Casner wrote:
> Greg,
>> But, if I try to vfs cat the file, ovms complains that the file
>> cannot be opened.
> Just checking... Is the complaint "Error: protected path"?  If so, you
> have to set:
> CONFIG_OVMS_DEV_CONFIGVFS=y
> in sdkconfig to allow access with the vfs commands.
