[Ovmsdev] Lessons learnt, production batch #2 and onwards
Michael Stegen
michael at stegen.com
Tue Apr 24 20:37:10 HKT 2018
I really liked the way athom.com did it with their 'Homey' home
automation device.
Their setup.homey.com page tells you step by step what to do, and
pre-loads the firmware update, so once you have connected to homey's
wifi hotspot, it can upgrade the firmware through the browser and
configure the device.
https://www.youtube.com/watch?v=ctAGzdC4rvc
-Michael
Op 23-4-2018 om 10:44 schreef Mark Webb-Johnson:
> Well, it has been an interesting few weeks as the first production
> batch of OVMS v3 came online. I don’t know about for others helping
> out with support tickets, but I’ve sure learned a lot - especially
> about what can go wrong for inexperienced users trying to setup a
> complex product. 14 support tickets were opened, along with another
> perhaps 6 calls for help via other means, and here are the most common
> problems encountered:
> * Switched from Access Point mode to Client mode, and lost access.
> * Can’t get into module via USB (drivers seem ok, but terminal
> emulators, and baud rates, are beyond most people’s understanding).
> * Too hard for most to do a factory reset.
> * Can’t see modem ICCID when powered off.
> * Modem powered off by default, unless the little tick box is clicked.
> * Server v2 off by default, unless the little tick box is clicked.
> * Upper vs lower case on command execution.
> * Unable to do firmware update in Access Point mode.
> * Password confusion (wifi client vs module vs server vehicle vs
> server account vs access point vs OVMSinit vs etc etc).
> * wifi vs modem switches and DNS settings.
> * Modem SIM registration issues (can’t see, or don’t know how to
> see, status of simcom).
> * Don’t understand how to check status.
> While some of these issues have been addressed, I am reluctant to
> release a new batch of modules to the world, especially this time with
> less technically capable users coming online.
> It is probably not ‘fun’ work, but I think we can make this much
> simpler for new users. We can lead them through the setup in the
> following stages:
> 1. Require, as a pre-requisite, users to initially setup the module
> within range of a home wifi / cellular hotspot connection.
> 2. Factory default, use Access Point mode, SSID OVMS password
> “OVMSinit”, and no module password. Have them connect to the
> module over wifi Access Point, and http://192.168.4.1/.
> 3. The web interface then shows them a list of WiFi access points in
> range, and asks them to choose one and enter the password for that
> access point (clearly labelled as SSID, and "<SSID> Password”).
> 4. The module then reconfigures as Client + Access Point mode, and
> tries to connect to the client wifi, as well as keeping the access
> point connection open. If not ok, tell them and go back to #3 for
> them to try again.
> 5. When ok, proceed to ask them to update the firmware. This will do
> a simple OTA download over HTTP, then reboot.
> 6. When back up, in one screen ask them to enter all the details for
> their network, and configure appropriately:
> * Use Wifi?
> o WiFi Mode (AccessPoint+SpecificClient, or ScanningClient)
> o OVMS Access Point SSID
> o New OVMS Access Point password (as OVMSinit is insecure
> beyond initial setup)
> * DNS (default: google, or custom)
> * Module password (as default empty is insecure beyond initial
> setup)
> * Use OVMS Server v2?
> o Vehicle type
> o Vehicle ID
> o Vehicle Server password
> o Vehicle server (openvehicles, dexter, or custom)
> * Use modem?
> o Modem APN, username and password (default: hologram)
> 7. Test each of the above, and show them the results. Set auto
> appropriately, and disable quickstart then reboot.
> The point is to lead them through each of the steps, test each setting
> and show them the result.
> Technically, my only concern is the switch from AP to AP+client mode
> and whether the existing wifi connection will die or survive the
> channel switch. We also have to do a wifi scan, in Access Point mode,
> but I think we can do that by just temporarily turning off access
> point or doing it before the access point is brought up. Both these
> will depend on how ESP32 handles it.
> I’m happy to do a lot (if not all) of the above, but will definitely
> need help with the web side.
> But, first let’s agree on the proper list of questions to ask and flow
> to follow.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180424/f58746c5/attachment.html>
