[Ovmsdev] Automatic vehicle notifications
Wed Apr 25 09:13:10 HKT 2018
It is time to implement vehicle notifications (charge started, charge completed, charge interrupted, etc) in the vehicle modules I am supporting. It seems that this can be done in the vehicle.{h,cpp} framework in a standard manner, and work across all vehicle types. However, I guess that will break any notifications already being produced by other vehicle types.
My suggestion is:
A config parameter ‘notifications’, with individual instances to turn on/off the notifications. Default is all enabled.
OvmsVehicle::MetricModified picks up metric changes and issues the standard notifications (checking ‘notifications’ parameter appropriately).
charge_mode=>charging: Notify charge started
charge_mode=>topoff: Notify charge started
charge_mode=>heating: Notify battery heating started
charge_mode=>done: Notify charge completed
charge_mode=>stopped: Notify charge interrupted
valet_mode=>on: Notify valet mode enabled
valet_mode=>off: Notify valet mode disabled
alarm=>on: Notify alarm is sounding
alarm=>off: Notify alarm is off
All the above should be suppressed for the initial setting of each parameter. I will have to look into metrics to see how best that should be done; one neat way is to keep a modification count (rather than the current m_defined boolean).
Does that make sense? Any objections/suggestions?
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180425/77fa5c32/attachment.html>
