[Ovmsdev] Leaf Updates
Sun Nov 19 21:49:37 HKT 2017
Tom,
> In v2 we checked whether transmit mode was enabled, I'm not seeing similar logic in the Telsa Roadster module. I've commented out the checks in the leaf code for the time being.
In v3, I haven’t bother with listen-only. Looking at connections to api.openvehicles.com <http://api.openvehicles.com/>, all but 2 vehicles have feature 15=1 (and those are probably mistakes by the end-user).
> In v2 I abstracted the hardware interactions necesary to write to the canbus into a function void vehicle_nissanleaf_send_can_message(short id, unsigned char length, unsigned char *data). In v3 we call canbus::Write(const CAN_frame_t* p_frame). Do we want to add a similar simpler "send to this buffer with this can id" method to the canbus object? The Leaf doesn't use any of the extended can features so a simple interface for the simple case seems to make sense. For the moment I've implemented it within the leaf codebase, see void OvmsVehicleNissanLeaf::SendCanMessage(uint16_t id, uint8_t length, uint8_t *data) in the pull request.
No harm in adding that, if you think it is useful. Please go ahead.
> I've also porting over the remote command features, I like the interface presented to the car modules to implement these. I need to wait until tomorrow to test these on a real car so haven't sent a pull request yet. I'm very close to finished on porting the leaf support!
Fantastic. Tesla Roadster is at a similar state.
> On 19 Nov 2017, at 10:46 AM, Tom Parker <tom at carrott.org> wrote:
> Hi,
> I ported over support for Gen 2 Chargers and polling for the battery Ah capacity and the "Hx" value in https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/pull/9
> 3 Questions:
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171119/efd57613/attachment.htm>
