[Ovmsdev] Android App 3.12.2 beta
Thu Dec 7 03:16:55 HKT 2017
Here's the next beta with optional monospace font:
https://dexters-web.de/f/tw-beta/OpenVehicleApp-debug-3.12.2b.apk
The web shell already uses a monospace font.
Am 06.12.2017 um 02:06 schrieb Mark Webb-Johnson:
> That is seriously cool. Coming together nicely.
> Mark
>> On 6 Dec 2017, at 4:20 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> Thanks to Mark implementing msg cmd 7, I'll also need to change the notifications font to monospace now… :)
>> <fdchkacifhdjcdfg.png>
>> Btw: this needs the server v2 task to have at least 8K stack to be usable (still will crash on larger command results, i.e. full metrics list).
>> Am 04.12.2017 um 23:13 schrieb Michael Balzer:
>>> Beta build of the next Android App release:
>>> https://dexters-web.de/f/tw-beta/OpenVehicleApp-debug-3.12.2.apk
>>> This supports the new float values sent by the new V2 server (hopefully got them all) so can again be used to connect to a V3 module.
>>> Float displays are not yet optimized but should do for now. Please note the Intent extras also have changed from int to float accordingly, so you may need
>>> to update your listeners. I'll prepare a new set of Automagic examples later on.
>>> There are also some optimizations regarding the ApiService stability and the layout, and some fixes.
>>> Please send me a logcat if you encounter crashes.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171206/8a4ab523/attachment.html>
