[Ovmsdev] Android App 3.12.2 beta
Mon Dec 18 04:48:48 HKT 2017
Mark gave me the play store keys, so I'm about to prepare the next public release. This is the release candidate:
https://dexters-web.de/f/tw-beta/OpenVehicleApp-debug-3.12.2c.apk
I've pushed all changes to the main repository and merged the gcm branch back into the master. I've also created a github wiki page for the Automagic scripts --
some have been provided by users on the german Twizy forum, I'll add them to the repository later on.
Please test this version thoroughly and report all problems & change requests to me.
Thanks & regards,
Release 3.12.2: - API service as Android foreground service - Message parsing refactored to CarData, exception encapsulation - CarData: added new fields (SOH,
drive mode & profile info, power, energy usage) - CarData: changed numeric integer fields to float/double for OVMS v3 - GcmListener: added notification type (v3
info/alert distinction) - UI: rearranged main tabs, allow all tabs in cache - UI: added help & monospace font options menu to notifications tab - UI: added
options menu to car tab (direct access to info/features/diag logs) - Database: fixed "sticky" notifications (wrong future timestamp) - Features editor v3
support: changed to text editor, allow variable number of features, added new Twizy features - General crash hardening - Notifications: added sending modem
("@…") & msg commands ("#…") - UI: options menu optimizations - Fix rt_cfg_applied for broadcasts
Am 06.12.2017 um 20:16 schrieb Michael Balzer:
> Here's the next beta with optional monospace font:
> https://dexters-web.de/f/tw-beta/OpenVehicleApp-debug-3.12.2b.apk
> The web shell already uses a monospace font.
> Am 06.12.2017 um 02:06 schrieb Mark Webb-Johnson:
>> That is seriously cool. Coming together nicely.
>> Mark
>>> On 6 Dec 2017, at 4:20 AM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>> Thanks to Mark implementing msg cmd 7, I'll also need to change the notifications font to monospace now… :)
>>> <fdchkacifhdjcdfg.png>
>>> Btw: this needs the server v2 task to have at least 8K stack to be usable (still will crash on larger command results, i.e. full metrics list).
>>> Am 04.12.2017 um 23:13 schrieb Michael Balzer:
>>>> Beta build of the next Android App release:
>>>> https://dexters-web.de/f/tw-beta/OpenVehicleApp-debug-3.12.2.apk
>>>> This supports the new float values sent by the new V2 server (hopefully got them all) so can again be used to connect to a V3 module.
>>>> Float displays are not yet optimized but should do for now. Please note the Intent extras also have changed from int to float accordingly, so you may need
>>>> to update your listeners. I'll prepare a new set of Automagic examples later on.
>>>> There are also some optimizations regarding the ApiService stability and the layout, and some fixes.
>>>> Please send me a logcat if you encounter crashes.
>>>> Regards,
>>>> Michael
>>>> OvmsDev mailing list
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171217/7ca5eca2/attachment-0001.html>
