[Ovmsdev] Android App 3.12.2 beta
Wed Dec 6 09:06:24 HKT 2017
That is seriously cool. Coming together nicely.
Mark
> On 6 Dec 2017, at 4:20 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Thanks to Mark implementing msg cmd 7, I'll also need to change the notifications font to monospace now… :)
> <fdchkacifhdjcdfg.png>
> Btw: this needs the server v2 task to have at least 8K stack to be usable (still will crash on larger command results, i.e. full metrics list).
> Am 04.12.2017 um 23:13 schrieb Michael Balzer:
>> Beta build of the next Android App release:
>> https://dexters-web.de/f/tw-beta/OpenVehicleApp-debug-3.12.2.apk <https://dexters-web.de/f/tw-beta/OpenVehicleApp-debug-3.12.2.apk>
>> This supports the new float values sent by the new V2 server (hopefully got them all) so can again be used to connect to a V3 module.
>> Float displays are not yet optimized but should do for now. Please note the Intent extras also have changed from int to float accordingly, so you may need to update your listeners. I'll prepare a new set of Automagic examples later on.
>> There are also some optimizations regarding the ApiService stability and the layout, and some fixes.
>> Please send me a logcat if you encounter crashes.
>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171206/1a722882/attachment.html>
