[Ovmsdev] Android App 3.12.2 beta
Wed Dec 6 04:20:49 HKT 2017
Thanks to Mark implementing msg cmd 7, I'll also need to change the notifications font to monospace now… :)
Btw: this needs the server v2 task to have at least 8K stack to be usable (still will crash on larger command results, i.e. full metrics list).
Am 04.12.2017 um 23:13 schrieb Michael Balzer:
> Beta build of the next Android App release:
> https://dexters-web.de/f/tw-beta/OpenVehicleApp-debug-3.12.2.apk
> This supports the new float values sent by the new V2 server (hopefully got them all) so can again be used to connect to a V3 module.
> Float displays are not yet optimized but should do for now. Please note the Intent extras also have changed from int to float accordingly, so you may need to
> update your listeners. I'll prepare a new set of Automagic examples later on.
> There are also some optimizations regarding the ApiService stability and the layout, and some fixes.
> Please send me a logcat if you encounter crashes.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171205/62ee6b51/attachment-0001.html>
Type: image/png
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20171205/62ee6b51/attachment-0001.png>
