[Ovmsdev] Storing Calibration Data
    Tom Parker
    tom at carrott.org
    Sun May  8 07:12:07 HKT 2016
On 05/07/2016 07:22 AM, Tom Saxton wrote:
> What I proposed was using data from the CAN bus to determine the Leaf pack size, then based on that use the appropriate nominal new pack Gids and rated range to calculate rated range from current SOC. I don't think that would require storing any parameter data. It's like the options on the Roadster based on v1.5 or v2.x.
I'm happy to do something like that, but I'd need someone to explain how
to tell the difference between a 30kWh battery and a 24kWh battery.
