[Ovmsdev] Nissan Leaf Remote Climate Control working on Gen 2
Wed May 4 19:14:26 HKT 2016
Tom,
there is no climate control command set yet, you
can introduce one. Try to define it as common as
possible, so it can be used for other vehicles as
well.
If you add the command set to the framework
instead of the Leaf module, take care to also add
a compiler option, as ROM space is very tight on
the Twizy.
Chris, a german Twizy & Leaf driver, also prepared
some Leaf images and asked me to add them to the
Android App.
I can add a simple climate control UI to the App
along with those images if you like.
Am 02.05.2016 um 12:39 schrieb Tom Parker:
> Hi,
> I had a chance to test my updated Nissan Leaf
> firmware on a Gen 2 Leaf and it just works. I
> still haven't made a circuit to interface with
> the wakeup wire on my Gen 1, but this isn't
> necessary for Gen 2.
> Currently I'm abusing the Homelink and Alert
> commands to turn on and off Climate Control. Is
> there a more suitable pair of commands? I've got
> the android app and I don't see an obvious user
> interface for controlling the air conditioning.
> Should climate control require a pin like unlock
> and valet mode do? I'm thinking it doesn't need
> one because it's already protected by the SMS
> source phone number and the module password?
> Even if the source phone number can be spoofed,
> the impact isn't too great.
> I also implemented remote charging (since it's
> the same CAN message with a different value), I
> haven't tested that.
> See
> https://carrott.org/git/Open-Vehicle-Monitoring-System.git/shortlog/refs/heads/nissan-leaf-climate-control
> for this firmware.
