[Ovmsdev] Nissan Leaf Remote Climate Control working on Gen 2
Fri May 6 11:11:36 HKT 2016
This can be a standardised command. There is room after #25 (cooldown), so #26, #27, #28, and #29 are available.
See OVMS_Protocol in docs for details.
I’m happy to make the change in the iOS App, if we can agree on the command numbers and parameters.
> On 4 May 2016, at 7:14 PM, Michael Balzer <dexter at expeedo.de> wrote:
> Tom,
> there is no climate control command set yet, you can introduce one. Try to define it as common as possible, so it can be used for other vehicles as well.
> If you add the command set to the framework instead of the Leaf module, take care to also add a compiler option, as ROM space is very tight on the Twizy.
> Chris, a german Twizy & Leaf driver, also prepared some Leaf images and asked me to add them to the Android App.
> I can add a simple climate control UI to the App along with those images if you like.
> Am 02.05.2016 um 12:39 schrieb Tom Parker:
>> Hi,
>> I had a chance to test my updated Nissan Leaf firmware on a Gen 2 Leaf and it just works. I still haven't made a circuit to interface with the wakeup wire on my Gen 1, but this isn't necessary for Gen 2.
>> Currently I'm abusing the Homelink and Alert commands to turn on and off Climate Control. Is there a more suitable pair of commands? I've got the android app and I don't see an obvious user interface for controlling the air conditioning.
>> Should climate control require a pin like unlock and valet mode do? I'm thinking it doesn't need one because it's already protected by the SMS source phone number and the module password? Even if the source phone number can be spoofed, the impact isn't too great.
>> I also implemented remote charging (since it's the same CAN message with a different value), I haven't tested that.
>> See https://carrott.org/git/Open-Vehicle-Monitoring-System.git/shortlog/refs/heads/nissan-leaf-climate-control for this firmware.
