[Ovmsdev] v2.8.5
Sat Mar 26 16:07:22 HKT 2016
Robert,
no. The master repository still only has the outdated V0.2 Kia Soul
module, that's not included in a build configuration by default.
Am 26.03.2016 um 00:56 schrieb Robert Cotran:
> Hi guys,
> This might be a real noob question, but the 2.8.5 firmware has 4
> versions for the V2 hardware:
> - experimental
> - production
> - RT production
> - TR production
> Would the Kia Soul EV code be part of the "production" version?
> Thanks!
> Robert
> On 3/14/2016 7:01 AM, Mark Webb-Johnson wrote:
>> OK, everything looks good to go and I am going to give manufacturing
>> go-ahead for a batch using SIM808 modules tonight.
>> The v2.8.5 firmware is required for SIM808 support, and I’ve built
>> binaries of those ready for release.
>> Please play with this, and let us know if you find any issues.
>> 2016-03-14 2.8.5       Firmware 2.8.5 SIM808 GSM/GPS module support
>>                        # Fix for Twizy build w/o BATTMON
>>                        # Twizy: ideal range calculated with
>> temperature influence approximation
>>                        # Twizy: Battery capacity estimation
>>                        # Twizy: Charge start restarts SOC window (to
>> get most recent BMS SOC)
>>                        # Twizy: Charge interruption no longer
>> restarts power sums & SOC window
>>                        # Added vehicle_version to net msg "F"
>>                        # New vehicle: Kia Soul EV, initial version
>> 0.1 (alpha/untested)
>>                        # Kia Soul: VIN, car status, doors & charging
>> status, SOC, estimated range, speed
>>                        # Framework: OBDII polling support for modes
>> 02, 10 & 21
>>                        # Kia Soul: DEBUG diag output fixed for SMS
>> size limit
>>                        # Kia Soul: ISR optimization - OBD diag data
>> init & length debugging
>>                        # Kia Soul: Buffer overflow protection for
>> OBDII multi frame polls
>>                        # Kia Soul: Init CAN RX filter 1 to avoid
>> noise triggers
>>                        # Twizy: optional current limit modification
>>                        # Added compiler switch OVMS_NO_CRASHDEBUG
>>                        # Twizy V3.7.0: - CFG POWER: max current
>> control, higher torque & power levels
>>                        # Framework v2.8.2: DIAG mode: support
>> backspace & ctrl-a / ctrl-c (= abort/clear)
>>                        # Framework v2.8.2: DIAG mode perl clients added
>>                        # Framework v2.8.2: DIAG mode documentation
>> extended
>>                        # Add hints on 0x100/0x96 and 0x400/0x01
>>                        # Framework: Fixed base64decode(), removed bug
>> workarounds
>>                        # Framework: base64encode(): return pointer to
>> end of base64 string
>>                        # Framework: New net_assert_caller(): check
>> caller, fallback to REGPHONE
>>                        # Framework: net_put RAM redirection now uses
>> net_buf[]
>>                        # Framework: Code cleanup, size and stack
>> depth optimization
>>                        # Framework: Fix: stack overflow/underflow
>> flags cleared after crash
>>                        # Framework: Perl diagmode clients: missing
>> license info added
>>                        # Twizy: Flux map optimization
>>                        # Twizy: Fix: "CA?" outputs ETR SOC if ETR
>> range is zero
>>                        # Twizy: CAN control bits to disable emergency
>> reset, kickdown & autopower
>>                        # Twizy: Flux & saturation maps added to
>> documentation
>>                        # Twizy: Updated SDO list & limits
>>                        # MPLABX 3.1x support, and OVMS_BUILDCONFIG to
>> show selected build config in version strings
>>                        # Add pics and docs on Tesla Model S new style
>> DIAG connector seen in late 2015 cars onwards
>>                        # Re-work GPS initialisation for SIM808
>>                        # Use AT+CGPSRST=0 for cold start of GPS
>>                        # Fix SMS VERSION command
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20160326/03d00933/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20160326/03d00933/attachment-0002.vcf>
