[Ovmsdev] v2.8.5
Robert Cotran
robert at cotran.ca
Sun Mar 27 03:37:31 HKT 2016
OK so I should be compiling it myself then yes?
On 3/26/2016 4:07 AM, Michael Balzer wrote:
> Robert,
> no. The master repository still only has the outdated V0.2 Kia Soul
> module, that's not included in a build configuration by default.
> Am 26.03.2016 um 00:56 schrieb Robert Cotran:
>> Hi guys,
>> This might be a real noob question, but the 2.8.5 firmware has 4
>> versions for the V2 hardware:
>> - experimental
>> - production
>> - RT production
>> - TR production
>> Would the Kia Soul EV code be part of the "production" version?
>> Thanks!
>> Robert
>> On 3/14/2016 7:01 AM, Mark Webb-Johnson wrote:
>>> OK, everything looks good to go and I am going to give manufacturing
>>> go-ahead for a batch using SIM808 modules tonight.
>>> The v2.8.5 firmware is required for SIM808 support, and I’ve built
>>> binaries of those ready for release.
>>> Please play with this, and let us know if you find any issues.
>>> 2016-03-14 2.8.5 Firmware 2.8.5 SIM808 GSM/GPS module support
>>> # Fix for Twizy build w/o BATTMON
>>> # Twizy: ideal range calculated with temperature influence
>>> approximation
>>> # Twizy: Battery capacity estimation
>>> # Twizy: Charge start restarts SOC window (to get most recent BMS
>>> SOC)
>>> # Twizy: Charge interruption no longer restarts power sums & SOC
>>> window
>>> # Added vehicle_version to net msg "F"
>>> # New vehicle: Kia Soul EV, initial version 0.1 (alpha/untested)
>>> # Kia Soul: VIN, car status, doors & charging status, SOC,
>>> estimated range, speed
>>> # Framework: OBDII polling support for modes 02, 10 & 21
>>> # Kia Soul: DEBUG diag output fixed for SMS size limit
>>> # Kia Soul: ISR optimization - OBD diag data init & length debugging
>>> # Kia Soul: Buffer overflow protection for OBDII multi frame polls
>>> # Kia Soul: Init CAN RX filter 1 to avoid noise triggers
>>> # Twizy: optional current limit modification
>>> # Added compiler switch OVMS_NO_CRASHDEBUG
>>> # Twizy V3.7.0: - CFG POWER: max current control, higher torque &
>>> power levels
>>> # Framework v2.8.2: DIAG mode: support backspace & ctrl-a /
>>> ctrl-c (= abort/clear)
>>> # Framework v2.8.2: DIAG mode perl clients added
>>> # Framework v2.8.2: DIAG mode documentation extended
>>> # Add hints on 0x100/0x96 and 0x400/0x01
>>> # Framework: Fixed base64decode(), removed bug workarounds
>>> # Framework: base64encode(): return pointer to end of base64 string
>>> # Framework: New net_assert_caller(): check caller, fallback to
>>> REGPHONE
>>> # Framework: net_put RAM redirection now uses net_buf[]
>>> # Framework: Code cleanup, size and stack depth optimization
>>> # Framework: Fix: stack overflow/underflow flags cleared after crash
>>> # Framework: Perl diagmode clients: missing license info added
>>> # Twizy: Flux map optimization
>>> # Twizy: Fix: "CA?" outputs ETR SOC if ETR range is zero
>>> # Twizy: CAN control bits to disable emergency reset, kickdown &
>>> autopower
>>> # Twizy: Flux & saturation maps added to documentation
>>> # Twizy: Updated SDO list & limits
>>> # MPLABX 3.1x support, and OVMS_BUILDCONFIG to show selected
>>> build config in version strings
>>> # Add pics and docs on Tesla Model S new style DIAG connector
>>> seen in late 2015 cars onwards
>>> # Re-work GPS initialisation for SIM808
>>> # Use AT+CGPSRST=0 for cold start of GPS
>>> # Fix SMS VERSION command
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20160326/fda48f26/attachment.htm>
