[Ovmsdev] v2.8.5
Robert Cotran
robert at cotran.ca
Sat Mar 26 07:56:46 HKT 2016
Hi guys,
This might be a real noob question, but the 2.8.5 firmware has 4
versions for the V2 hardware:
- experimental
- production
- RT production
- TR production
Would the Kia Soul EV code be part of the "production" version?
Thanks!
Robert
On 3/14/2016 7:01 AM, Mark Webb-Johnson wrote:
> OK, everything looks good to go and I am going to give manufacturing
> go-ahead for a batch using SIM808 modules tonight.
> The v2.8.5 firmware is required for SIM808 support, and I’ve built
> binaries of those ready for release.
> Please play with this, and let us know if you find any issues.
> 2016-03-14 2.8.5 Firmware 2.8.5 SIM808 GSM/GPS module support
> # Fix for Twizy build w/o BATTMON
> # Twizy: ideal range calculated with
> temperature influence approximation
> # Twizy: Battery capacity estimation
> # Twizy: Charge start restarts SOC window (to
> get most recent BMS SOC)
> # Twizy: Charge interruption no longer restarts
> power sums & SOC window
> # Added vehicle_version to net msg "F"
> # New vehicle: Kia Soul EV, initial version 0.1
> (alpha/untested)
> # Kia Soul: VIN, car status, doors & charging
> status, SOC, estimated range, speed
> # Framework: OBDII polling support for modes
> 02, 10 & 21
> # Kia Soul: DEBUG diag output fixed for SMS
> size limit
> # Kia Soul: ISR optimization - OBD diag data
> init & length debugging
> # Kia Soul: Buffer overflow protection for
> OBDII multi frame polls
> # Kia Soul: Init CAN RX filter 1 to avoid noise
> triggers
> # Twizy: optional current limit modification
> # Added compiler switch OVMS_NO_CRASHDEBUG
> # Twizy V3.7.0: - CFG POWER: max current
> control, higher torque & power levels
> # Framework v2.8.2: DIAG mode: support
> backspace & ctrl-a / ctrl-c (= abort/clear)
> # Framework v2.8.2: DIAG mode perl clients added
> # Framework v2.8.2: DIAG mode documentation
> extended
> # Add hints on 0x100/0x96 and 0x400/0x01
> # Framework: Fixed base64decode(), removed bug
> workarounds
> # Framework: base64encode(): return pointer to
> end of base64 string
> # Framework: New net_assert_caller(): check
> caller, fallback to REGPHONE
> # Framework: net_put RAM redirection now uses
> net_buf[]
> # Framework: Code cleanup, size and stack depth
> optimization
> # Framework: Fix: stack overflow/underflow
> flags cleared after crash
> # Framework: Perl diagmode clients: missing
> license info added
> # Twizy: Flux map optimization
> # Twizy: Fix: "CA?" outputs ETR SOC if ETR
> range is zero
> # Twizy: CAN control bits to disable emergency
> reset, kickdown & autopower
> # Twizy: Flux & saturation maps added to
> documentation
> # Twizy: Updated SDO list & limits
> # MPLABX 3.1x support, and OVMS_BUILDCONFIG to
> show selected build config in version strings
> # Add pics and docs on Tesla Model S new style
> DIAG connector seen in late 2015 cars onwards
> # Re-work GPS initialisation for SIM808
> # Use AT+CGPSRST=0 for cold start of GPS
> # Fix SMS VERSION command
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20160325/915561d0/attachment.htm>
