[Ovmsdev] Twizy release 3.6.1
Fran Terry fterry at tesco.net
Mon Oct 26 22:34:11 HKT 2015
Hi Micheal,
Seems to be an issue with this new version, not geting any notifications
from OVMS via IP, not tried this via SMS yet. If I send a command via
Andoird App, system sends back reply OK.
Also noticed a possible issue with CFG profile not applying before each
trip.
Currently have feature #14 set to 0, however also tried with 64.
Any ideas?
Thanks
Fran
On 03/10/2015 17:49, Michael Balzer wrote:
> Package:
>   http://dexters-web.de/f/tw/OVMS-Twizy-3.6.1.zip
> Changes:
>   see tag "V3.6" in the user guide
> Framework V2.7.4:
> - New compiler switches to disable framework functions:
>    OVMS_NO_CHARGECONTROL
>    OVMS_NO_CTP
>    OVMS_NO_SMSTIME
>    OVMS_NO_VEHICLE_ALERTS
>    (all need to be set for Twizy build)
> - Potential buffer overflow fix in net_msg_forward_sms()
> - Fix stp_l2f() for negative values
> - Fix SMS MSG wrapper for long commands
> Framework V2.8.1:
> - Make COPS more lenient
> - Support GPRS DNS
> Twizy V3.6.0:
> - New: All power values now based on real battery power (current * voltage)
> - Battery current sums + min/max moved to separate fields
> - STAT command extended by grid energy drain estimation
> - RT-GPS-Log extended by BMS limits, auto power levels and battery
> current min/max
> - RT-PWR-Log extended by battery coulomb counts (Ah)
> - "RT-PWR-UsageStats" is now "RT-PWR-Stats", fields reordered and units
> converted
>    (to save space), coulomb count discharge/charge sums added (Ah)
> - Rework & bug fixes in auto power adjustment
> - Auto RECUP power adjustment extended by 100% reference power
>    (ATT: CFG RECUP parameters changed!)
> - New: auto DRIVE power adjustment
>    (ATT: CFG DRIVE parameters changed!)
> - New: CFG CLEAR = clear SEVCON diagnostic logs
> - Now using GSM time (NET_FN_CARTIME) for more accurate parking times
> - New: feature #14 & 64 = send notification on charge starts
> - Fixed charge time estimation for SOC > 94%
> - ISR performance optimization
> - car_SOC no longer rounded to avoid 99.5% == 100%
> - Trip end odometer saved & used for RT-PWR-Log charge entries
> - Fixed auto power minprc calculation with default (-1)
> - Fixed auto power calculations for default minprc values
> - Changed auto recup level to scale levels configured
> Twizy V3.6.1:
> - Fix: battery alert state also remembered for IP notification
> - Fix: compiling without OVMS_TWIZY_CFG
> - ideal range calculated with temperature influence approximation
> - Battery capacity estimation
> - Charge start restarts SOC window (to get most recent BMS SOC)
> - Charge interruption no longer restarts power sums & SOC window
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20151026/5c802610/attachment.htm>
