[Ovmsdev] Twizy release 3.6.1
Sun Oct 4 00:49:38 HKT 2015
Package:
 http://dexters-web.de/f/tw/OVMS-Twizy-3.6.1.zip
Changes:
 see tag "V3.6" in the user guide
Framework V2.7.4:
- New compiler switches to disable framework functions:
  OVMS_NO_CHARGECONTROL
  OVMS_NO_CTP
  OVMS_NO_SMSTIME
  OVMS_NO_VEHICLE_ALERTS
  (all need to be set for Twizy build)
- Potential buffer overflow fix in net_msg_forward_sms()
- Fix stp_l2f() for negative values
- Fix SMS MSG wrapper for long commands
Framework V2.8.1:
- Make COPS more lenient
- Support GPRS DNS
Twizy V3.6.0:
- New: All power values now based on real battery power (current * voltage)
- Battery current sums + min/max moved to separate fields
- STAT command extended by grid energy drain estimation
- RT-GPS-Log extended by BMS limits, auto power levels and battery
current min/max
- RT-PWR-Log extended by battery coulomb counts (Ah)
- "RT-PWR-UsageStats" is now "RT-PWR-Stats", fields reordered and units
converted
  (to save space), coulomb count discharge/charge sums added (Ah)
- Rework & bug fixes in auto power adjustment
- Auto RECUP power adjustment extended by 100% reference power
  (ATT: CFG RECUP parameters changed!)
- New: auto DRIVE power adjustment
  (ATT: CFG DRIVE parameters changed!)
- New: CFG CLEAR = clear SEVCON diagnostic logs
- Now using GSM time (NET_FN_CARTIME) for more accurate parking times
- New: feature #14 & 64 = send notification on charge starts
- Fixed charge time estimation for SOC > 94%
- ISR performance optimization
- car_SOC no longer rounded to avoid 99.5% == 100%
- Trip end odometer saved & used for RT-PWR-Log charge entries
- Fixed auto power minprc calculation with default (-1)
- Fixed auto power calculations for default minprc values
- Changed auto recup level to scale levels configured
Twizy V3.6.1:
- Fix: battery alert state also remembered for IP notification
- Fix: compiling without OVMS_TWIZY_CFG
- ideal range calculated with temperature influence approximation
- Battery capacity estimation
- Charge start restarts SOC window (to get most recent BMS SOC)
- Charge interruption no longer restarts power sums & SOC window
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20151003/a0a8d566/attachment-0002.vcf>
