[Ovmsdev] Building with free C18 compiler
Magnus Wik Amundrød
magnus at molbach.no
Thu Nov 19 18:48:37 HKT 2015
Any news on the Miev pre heating.
I'm a RCH from buying one, I just want this going.
Br.
On Nov 14, 2015, at 3:02 PM, lee colleton wrote:
> How's the i-MiEV support coming along? Do you still need test subjects?
> On Fri, Jun 20, 2014 at 6:29 AM, Matt Beard OVMS <smvo at mxf.org.uk> wrote:
> Was anyone able to build with my modified version of vehicle_mitsubishi.c ?
> I would really like to use this code for some tests this weekend.
> Matt Beard
> On 18 June 2014 19:14, Matt Beard OVMS <smvo at mxf.org.uk> wrote:
> Here is my modified code to try...
> I would love a copy of the hex file if it seems ok
> Matt
> On 18 June 2014 16:16, Thomas Bergo <thomas.bergo at gmail.com> wrote:
> There has not been any changes to the code since January. I don't remember doing any changes to the charge detection and the code should still reports 125A on quick charge as before.
> Please send the source code, and I will add it to the code.
> Regards, Thomas
> Den onsdag 18. juni 2014 skrev Matt Beard <matt at beard.tv> følgende:
> Nikolay,
> My earlier code had charge voltage and current during quick charge. I have copied over the functionality, but am not able to test - I will send the source when back on my PC.
> Matt Beard
> On Wednesday, June 18, 2014, Nikolay Shishkov <nshishkov at yahoo.com> wrote:
> Hi Matt,
> What is the issue you found in the Miev code?
> I am currently working on it and would be glad to incorporate that in my build and tests.
> Github removed support for WinXP so I can not use it to put my code there, but can send you my version of the mitsubishi code as an attachment if you like?
> Nikolay
> On Wednesday, June 18, 2014 3:20 PM, Matt Beard <matt at beard.tv> wrote:
> Have I missed a decision to no longer support the free C18 compiler - or has it been like that for ages?
> I am trying to fix an issue in the iMiev code, but can no longer build 2.6.5 due to needing the full compiler and no way am I paying £300 for it.
> Matt Beard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20151119/7018a1d8/attachment.html>
