[Ovmsdev] Building with free C18 compiler
lee colleton
lee at colleton.net
Sat Nov 14 22:02:39 HKT 2015
How's the i-MiEV support coming along? Do you still need test subjects?
On Fri, Jun 20, 2014 at 6:29 AM, Matt Beard OVMS <smvo at mxf.org.uk> wrote:
> Was anyone able to build with my modified version of vehicle_mitsubishi.c ?
> I would really like to use this code for some tests this weekend.
> Matt Beard
> On 18 June 2014 19:14, Matt Beard OVMS <smvo at mxf.org.uk> wrote:
>> Here is my modified code to try...
>> I would love a copy of the hex file if it seems ok
>> Matt
>> On 18 June 2014 16:16, Thomas Bergo <thomas.bergo at gmail.com> wrote:
>>> There has not been any changes to the code since January. I don't
>>> remember doing any changes to the charge detection and the code
>>> should still reports 125A on quick charge as before.
>>> Please send the source code, and I will add it to the code.
>>> Regards, Thomas
>>> Den onsdag 18. juni 2014 skrev Matt Beard <matt at beard.tv> følgende:
>>>> Nikolay,
>>>> My earlier code had charge voltage and current during quick charge. I
>>>> have copied over the functionality, but am not able to test - I will send
>>>> the source when back on my PC.
>>>> Matt Beard
>>>> On Wednesday, June 18, 2014, Nikolay Shishkov <nshishkov at yahoo.com>
>>>> wrote:
>>>>> Hi Matt,
>>>>> What is the issue you found in the Miev code?
>>>>> I am currently working on it and would be glad to incorporate that in
>>>>> my build and tests.
>>>>> Github removed support for WinXP so I can not use it to put my code
>>>>> there, but can send you my version of the mitsubishi code as an attachment
>>>>> if you like?
>>>>> Nikolay
>>>>> On Wednesday, June 18, 2014 3:20 PM, Matt Beard <matt at beard.tv> wrote:
>>>>> Have I missed a decision to no longer support the free C18 compiler -
>>>>> or has it been like that for ages?
>>>>> I am trying to fix an issue in the iMiev code, but can no longer build
>>>>> 2.6.5 due to needing the full compiler and no way am I paying £300 for it.
>>>>> Matt Beard
>>>>> OvmsDev mailing list
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20151114/d277b1ff/attachment.html>
