[Ovmsdev] Building with free C18 compiler
Matt Beard OVMS smvo at mxf.org.uk
Thu Jun 19 02:14:21 HKT 2014
Here is my modified code to try...
I would love a copy of the hex file if it seems ok
Matt
On 18 June 2014 16:16, Thomas Bergo <thomas.bergo at gmail.com> wrote:
> There has not been any changes to the code since January. I don't remember
> doing any changes to the charge detection and the code should still reports
> 125A on quick charge as before.
> Please send the source code, and I will add it to the code.
> Regards, Thomas
> Den onsdag 18. juni 2014 skrev Matt Beard <matt at beard.tv> følgende:
>> Nikolay,
>> My earlier code had charge voltage and current during quick charge. I
>> have copied over the functionality, but am not able to test - I will send
>> the source when back on my PC.
>> Matt Beard
>> On Wednesday, June 18, 2014, Nikolay Shishkov <nshishkov at yahoo.com>
>> wrote:
>>> Hi Matt,
>>> What is the issue you found in the Miev code?
>>> I am currently working on it and would be glad to incorporate that in my
>>> build and tests.
>>> Github removed support for WinXP so I can not use it to put my code
>>> there, but can send you my version of the mitsubishi code as an attachment
>>> if you like?
>>> Nikolay
>>>   On Wednesday, June 18, 2014 3:20 PM, Matt Beard <matt at beard.tv> wrote:
>>> Have I missed a decision to no longer support the free C18 compiler - or
>>> has it been like that for ages?
>>> I am trying to fix an issue in the iMiev code, but can no longer build
>>> 2.6.5 due to needing the full compiler and no way am I paying £300 for it.
>>> Matt Beard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140618/30d716f4/attachment.htm>
Type: text/x-csrc
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140618/30d716f4/attachment-0002.bin>
