[Ovmsdev] Building with free C18 compiler
Thomas Bergo
thomas.bergo at gmail.com
Wed Jun 18 23:16:31 HKT 2014
There has not been any changes to the code since January. I don't remember
doing any changes to the charge detection and the code should still reports
125A on quick charge as before.
Please send the source code, and I will add it to the code.
Regards, Thomas
Den onsdag 18. juni 2014 skrev Matt Beard <matt at beard.tv> følgende:
> Nikolay,
> My earlier code had charge voltage and current during quick charge. I have
> copied over the functionality, but am not able to test - I will send the
> source when back on my PC.
> Matt Beard
> On Wednesday, June 18, 2014, Nikolay Shishkov <nshishkov at yahoo.com
> <javascript:_e(%7B%7D,'cvml','nshishkov at yahoo.com');>> wrote:
>> Hi Matt,
>> What is the issue you found in the Miev code?
>> I am currently working on it and would be glad to incorporate that in my
>> build and tests.
>> Github removed support for WinXP so I can not use it to put my code
>> there, but can send you my version of the mitsubishi code as an attachment
>> if you like?
>> Nikolay
>> On Wednesday, June 18, 2014 3:20 PM, Matt Beard <matt at beard.tv
>> <javascript:_e(%7B%7D,'cvml','matt at beard.tv');>> wrote:
>> Have I missed a decision to no longer support the free C18 compiler - or
>> has it been like that for ages?
>> I am trying to fix an issue in the iMiev code, but can no longer build
>> 2.6.5 due to needing the full compiler and no way am I paying £300 for it.
>> Matt Beard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140618/de09e80c/attachment.htm>
