[Ovmsdev] Building with free C18 compiler
Matt Beard matt at beard.tv
Wed Jun 18 22:58:49 HKT 2014
Nikolay,
My earlier code had charge voltage and current during quick charge. I have
copied over the functionality, but am not able to test - I will send the
source when back on my PC.
Matt Beard
On Wednesday, June 18, 2014, Nikolay Shishkov <nshishkov at yahoo.com> wrote:
> Hi Matt,
> What is the issue you found in the Miev code?
> I am currently working on it and would be glad to incorporate that in my
> build and tests.
> Github removed support for WinXP so I can not use it to put my code there,
> but can send you my version of the mitsubishi code as an attachment if you
> like?
> Nikolay
>   On Wednesday, June 18, 2014 3:20 PM, Matt Beard <matt at beard.tv> wrote:
> Have I missed a decision to no longer support the free C18 compiler - or
> has it been like that for ages?
> I am trying to fix an issue in the iMiev code, but can no longer build
> 2.6.5 due to needing the full compiler and no way am I paying £300 for it.
> Matt Beard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140618/3f75c7cd/attachment.htm>
