[Ovmsdev] Building with free C18 compiler
Matt Beard OVMS
smvo at mxf.org.uk
Fri Jun 20 21:29:15 HKT 2014
Was anyone able to build with my modified version of vehicle_mitsubishi.c ?
I would really like to use this code for some tests this weekend.
Matt Beard
On 18 June 2014 19:14, Matt Beard OVMS <smvo at mxf.org.uk> wrote:
> Here is my modified code to try...
> I would love a copy of the hex file if it seems ok
> Matt
> On 18 June 2014 16:16, Thomas Bergo <thomas.bergo at gmail.com> wrote:
>> There has not been any changes to the code since January. I don't
>> remember doing any changes to the charge detection and the code
>> should still reports 125A on quick charge as before.
>> Please send the source code, and I will add it to the code.
>> Regards, Thomas
>> Den onsdag 18. juni 2014 skrev Matt Beard <matt at beard.tv> følgende:
>>> Nikolay,
>>> My earlier code had charge voltage and current during quick charge. I
>>> have copied over the functionality, but am not able to test - I will send
>>> the source when back on my PC.
>>> Matt Beard
>>> On Wednesday, June 18, 2014, Nikolay Shishkov <nshishkov at yahoo.com>
>>> wrote:
>>>> Hi Matt,
>>>> What is the issue you found in the Miev code?
>>>> I am currently working on it and would be glad to incorporate that in
>>>> my build and tests.
>>>> Github removed support for WinXP so I can not use it to put my code
>>>> there, but can send you my version of the mitsubishi code as an attachment
>>>> if you like?
>>>> Nikolay
>>>> On Wednesday, June 18, 2014 3:20 PM, Matt Beard <matt at beard.tv>
>>>> wrote:
>>>> Have I missed a decision to no longer support the free C18 compiler -
>>>> or has it been like that for ages?
>>>> I am trying to fix an issue in the iMiev code, but can no longer build
>>>> 2.6.5 due to needing the full compiler and no way am I paying £300 for it.
>>>> Matt Beard
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20140620/8bd58199/attachment.htm>
