[Ovmsdev] OVMS v3
Mastro Gippo
gipmad at gmail.com
Tue Jun 17 04:35:21 HKT 2014
Michael,
oddly enough the Wifi+bluetooth may cost more and be harder to develop than
a GSM modem... and an OVMS with only USB / BT / WIFI conection would then
become only slightly better than an ELM327.
Lowering power consumption is nearly impossible because of the required
connection, but we can make an option for the twizy to turn off the modem
when the car is not charging or is not on. It shouldn't be an issue because
having a connection is useless anyway as the twizy doesn't have things
(A/C) to remotely control when the car is turned off.
What are you talking about the Samsung NX300? I don't see anything
impressive, 160 minutes of battery time on 1100mah is pretty standard...
MG
2014-06-16 22:22 GMT+02:00 Michael Balzer <dexter at expeedo.de>:
> Twizy users don't need locking / pre-heating etc., the controller
> parameter tuning is the currently most important Twizy OVMS feature (not
> available on other cars up to now).
> Twizy user feedback:
> The current OVMS is far too complex for normal people.
> GSM is good as an option, but bad as a requirement. Needing to buy and
> insert a SIM card is already too much for many. GSM reliability and
> availability also is an issue for serious telemetry. The most simple
> logging setup should work with just an SD / USB memory stick, readable on
> any PC.
> An OVMS v3 core version should be able to work with just a local Wifi /
> Bluetooth / USB connection. That could mean the GSM/GPS module becomes an
> extension module.
> An optional separate display console could make it possible to use the
> OVMS even without a smartphone / laptop.
> Software updates need to be possible without unmounting the OVMS, the
> PICkit flash procedure is way too much for ordinary users.
> Average power consumption needs to be lower than now by a factor of ~10,
> it's bad needing to remember unplugging the OVMS if you leave for a week.
> OVMS v3 also needs an ECE approval so it can be sold legally in Europe.
> Price may be higher than now then, by about 50-100%.
> Linux would be great and would open the path to a broad user community,
> but I doubt that can be combined with the low power usage and pricing
> requirements... although, the Samsung NX300 shows it's already been done --
> I have no idea about their hardware base though.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140616/57b1be5a/attachment.html>
