[Ovmsdev] Github Re-Organisation
Wed Jan 22 11:53:50 HKT 2014
Github now has a 'Organisations' feature that seems better suited to what we are doing.
Accordingly, I've created an organisation 'openvehicles', and migrated the four main repositories to that new organisation. The github URLs are now:
https://github.com/openvehicles/Open-Vehicle-Monitoring-System
https://github.com/openvehicles/Open-Vehicle-Android
https://github.com/openvehicles/Open-Vehicle-iOS
https://github.com/openvehicles/CAN-RE-Tool
Looks much nicer, and the most important point is that organisations can have multiple owners.
Supposedly the old 'markwj' repositories will continue to work (and be redirected).
What is broken (probably) is the permissions system. I'm setting up teams for this now, and will send out invites to / add the previous users with write-access, to join those teams. I should be done today, and then it should be back working again.
P.S. This is important, of course, in case I get run over by a bus. That said, if it happens I sure hope it is at least an electric bus ;-)
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140122/e6f84514/attachment.html>
