[Ovmsdev] Twizy45 testing needed
Sun Jan 26 02:48:12 HKT 2014
SEVCON configuration support for the Twizy 45 is basically complete, but
untested.
Unfortunately, the Twizy45 owner who provided the data readout is
currently unable to do the test.
So, if there are T45 drivers here willing to test, please use the
attached firmware build.
To check the source, see:
https://github.com/dexterbg/Open-Vehicle-Monitoring-System
FYI:
- max speed configurable is 78 kph
- max torque is 36 Nm (default 32,5)
- power levels of 130% should be possible, but watch temperatures
The ZIP contains a script of test commands with expected results to
check the basic operation before test driving.
Type: application/zip
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140125/72b76961/attachment-0001.zip>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140125/72b76961/attachment-0001.vcf>
