[Ovmsdev] i-Miev/C-Zero/iOn
Thomas Bergo
thomas.bergo at gmail.com
Fri Jan 24 05:52:51 HKT 2014
It's alive!!
Your last fix did it, I'm now on 2.6.2 FW.
Den torsdag 23. januar 2014 skrev Mark Webb-Johnson <mark at webb-johnson.net>
følgende:
> Michael,
> Yep, that’s it.
> Problem is OVMS_POLLER is a compile-time definition, so it must be shared
> by all cars in the configuration. I’ve re-worked it slightly to call the
> poll0 function even there is no poll list defined:
> diff --git a/vehicle/OVMS.X/vehicle.c b/vehicle/OVMS.X/vehicle.c
> index 9c1e9d9..a706bf1 100644
> --- a/vehicle/OVMS.X/vehicle.c
> +++ b/vehicle/OVMS.X/vehicle.c
> @@ -295,15 +295,21 @@ void high_isr(void)
> can_databuffer[7] = RXB0D7;
> RXB0CONbits.RXFUL = 0; // All bytes read, Clear flag
> #ifdef OVMS_POLLER
> - if ((vehicle_poll_plist != NULL)&&
> - (can_id >= vehicle_poll_moduleid_low)&&
> - (can_id <= vehicle_poll_moduleid_high))
> + if (vehicle_poll_plist != NULL)
> - if (vehicle_poll_poll0())
> + if ((can_id >= vehicle_poll_moduleid_low)&&
> + (can_id <= vehicle_poll_moduleid_high))
> - vehicle_fn_poll0();
> + if (vehicle_poll_poll0())
> + vehicle_fn_poll0();
> + else
> #else // #ifdef OVMS_POLLER
> vehicle_fn_poll0();
> #endif //#ifdef OVMS_POLLER
> I hope this fixes it.
> Thomas: Can you try to build this version (it is in github master now).
> On 23 Jan, 2014, at 4:29 pm, Michael Balzer <dexter at expeedo.de<javascript:_e({}, 'cvml', 'dexter at expeedo.de');>>
> wrote:
> Mark,
> if the Mitsubishi code does not use the new polling hooks, poll0() will
> not be called if the polling code is compiled in.
> I had the same problem for the Twizy, that's why I introduced the
> OVMS_POLLER compiler switch.
> Am 22.01.2014 02:18, schrieb Mark Webb-Johnson:
> Thomas,
> Strange. So far, I see 4 cars using 2.6.2, but only one (presumably
> yours) is showing authentication errors.
> I also can't see any changes to the vehicle_mitsubishi.c code that would
> cause poll0 to stop working. It is certainly working in other vehicle
> modules.
> I'll keep looking, but would be grateful if you could try to narrow down
> the poll0 problem.
> On 22 Jan, 2014, at 5:00 am, Thomas Bergo <thomas.bergo at gmail.com> wrote:
> Mark,
> Was testing the new 2.6.2 code on i-Miev today.
> Two observations:
> - Lots of restarts and "Vehicle authentication failed" messages in the iOS
> app
> - No CAN bus messages form PID in poll0, while messages in poll1 is
> working OK.
> Programmed the OVMS module with a version, and verified that the module
> was OK.
> Regards, Thomas
> 2013/10/30 Thomas Bergo <thomas.bergo at gmail.com>
> Matt,
> Please report back when you have done some testing on the QC.
> If the car report 0A while QC, the current code will not detect that we
> are charging. So then we need to rely on the estimated range reported as
> 255 to detecting that the car is QC.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20140123/47163b0e/attachment-0001.html>
