[Ovmsdev] i-Miev/C-Zero/iOn
Matt Beard matt at beard.tv
Thu Oct 17 14:10:33 HKT 2013
I hope to be able to do so in the next day or so.
Matt
On Wednesday, October 16, 2013, Thomas Bergo wrote:
> Greate work.
> If you share your discoveries and your code, I can also do some testing.
> Regards, Thomas
> onsdag 16. oktober 2013 skrev Matt Beard følgende:
> I was wrong about the bus being quiet during RC and have figured out how
> to detect rapid charging.
> Also I've found the AC charger temperature (which should probably go in
> PEM temperature) and I'm pretty certain I have found the motor temperature
> (but I need to do more testing). What I really want is the ambient
> temperature, but no sign yet. Any ideas?
> Matt Beard
> On Friday, September 27, 2013, Matt Beard OVMS wrote:
> Has anyone seen a CAN log from a rapid charge?
> Is the OBD port active at all during rapid charge? I found nothing gets
> reported during RC.
> Matt
> On 26 September 2013 10:29, Thomas Bergo <thomas.bergo at gmail.com> wrote:
> Ok, then you have the same issue.
> Will look into this later.
> Regards, Thomas
> 2013/9/26 Matt Beard OVMS <smvo at mxf.org.uk>
> My STAT? gives:
> Not charging
>  SOC: 100%
>  Ideal Range: 93 mi
>  Est. Range 68 mi
> On 26 September 2013 10:02, Thomas Bergo <thomas.bergo at gmail.com> wrote:
> Matt:
> Do you get the ODO in the "STAT?" SMS message?  I did until two days ago,
> did a cleanup of the code before push to GitHub. After that i haven't got
> ODO.  Can't see any changes to the code from the previous version ether.
> Regards, Thomas
> 2013/9/25 Matt Beard OVMS <smvo at mxf.org.uk>
> Having disconnected OVMS and power-cycled the car the charge seemed to be
> going OK, so I connected the unit back up and let it go the last 50% or so
> with OVMS and it was still fine. So, looks like something set a bad value!
> Maybe there is a "set max % charge" CAN message and it got set due to noise
> on the bus. Wish I knew what it was!
> Matt
> On 25 September 2013 14:35, Thomas Bergo <thomas.bergo at gmail.com> wrote:
> How did the rest of the charging go?
> Any other hick ups?
> Regards,Thomas
> onsdag 25. september 2013 skrev Matt Beard følgende:
> The SOC was about 25%
> Matt
> On Tuesday, 24 September 2013, Thomas Bergo wrote:
> Was the SOC approximately 70% ?
> The Car takes a pause and stops charging for some time at 70%. I belive
> this is to level the charge state of the cells. After some time the
> charging will continue.
> Regards, Thomas
> tirsdag 24. september 2013 skrev Matt Beard følgende:
> More strange behaviour with my C-Zero.
> Trying to investigate charging current today I discovered that the car
> would not charge for longer than a couple of minutes with the OVMS
> connected (with Thomas' image loaded). It would start charging, then the
> current would drop to zero, but the charge light stayed on. After a while
> it stopped even trying to charge. Disconnecting the OVMS didn't fix it
> until I also turned the car on and off again (with the OVMS not connected).
> Did can noise cause problems again?
> Matt
> On Tuesday, September 24, 2013, Thomas Bergo wrote:
> The first models (2011) was delivered with a 16A cable. This was changed
> for the later models (2012 ->) to 10A cable do to firesafty.
> At home i use a 16A cable for charging, but the car only draw 13A.
> I'm not sure what is the correct info, EVSE limit or the charger limit.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131017/676346a5/attachment.htm>
