[Ovmsdev] 12V battery alerts
Håkon Markussen hakon.markussen at gmail.com
Wed Nov 13 15:51:14 HKT 2013
False 12V alerts disappeared when triggering alert from ref - 2,0V.
    // Trigger 12V alert if voltage <= ref - 1.5 V:
    if (!(can_minSOCnotified & CAN_MINSOC_ALERT_12V)
            && (car_12vline <= (car_12vline_ref - *20*)))
      can_minSOCnotified |= CAN_MINSOC_ALERT_12V;
      net_req_notification(NET_
NOTIFY_12VLOW);
Br.
Håkon
2013/11/12 Håkon Markussen <hakon.markussen at gmail.com>
> When setting Notifications (parameter #3) to "IP" or "SMSIP" I finally
> receive alerts - including Minimum SOC (feature #9) ;)
> The 12V Critical Alert triggers quite often, even if my 12V-battery is new
> and in top condition.
> I've measured that the car_12vline reports ~0,5V less than the real
> battery voltage, so I plan to change the file net.c (line 1458) from:
> *    // Trigger 12V alert if voltage <= ref - 1.5 V:     if
> (!(can_minSOCnotified & CAN_MINSOC_ALERT_12V)            && (car_12vline <=
> (car_12vline_ref - 15)))    {      can_minSOCnotified |=
> CAN_MINSOC_ALERT_12V;      net_req_notification(NET_NOTIFY_12VLOW);     }*
> to:
> and compile it to a local hex-build and test in on my Think City.
> Keep you posted about the result.
> Best regards.
> Håkon
> 2013/10/30 Mark Webb-Johnson <mark at webb-johnson.net>
>> Can someone try it at 2.0V (rather than 1.5V) and see if it solves the
>> false-alerts problem?
>> On 29 Oct, 2013, at 5:10 pm, Rolf Welde Skeie <rwskeie at gmail.com> wrote:
>> > Ok, it seems like a few have similar issues.
>> > The logic behind the calculations seems to be reasonable, it is the
>> assumption that there is a 1.5V difference between charging/non-charging
>> state which is not generally applicable.
>> > From my observations it seems like increasing this to 2.0V would take
>> care of most mis-firing events.?..
>> > Disclaimer: I'm not an expert on batteries...
>> > Running on 2.5.5 experimental/TC
>> > Rolf
>> > On 10/29/2013 10:00 AM, Matt Beard OVMS wrote:
>> >> Yup, I also get this message and it would be great if it were working
>> >> properly, but it actually fires at 13.1V which is far too high.
>> >> Matt
>> >> On 29 October 2013 08:46, Rolf Welde Skeie <rwskeie at gmail.com
>> >> <mailto:rwskeie at gmail.com>> wrote:
>> >>    I have the following features set:
>> >>    #0=1, #8=1, #9=1, #15=1, all others =0.
>> >>    Can't remember which one made it work, but one of them did, my guess
>> >>    would be #9 :)
>> >>    Rolf
>> >>    On 10/29/2013 09:38 AM, Håkon Markussen wrote:
>> >>        I never get this alert.
>> >>        I have a Think City (as Rolf Skeie) and use the iOS-app.
>> >>        I have tested on both an exhausted aux-battery and on a brand
>> new
>> >>        battery in perfect condition.
>> >>        Br.
>> >>        Håkon
>> >>        2013/10/29 Thomas Bergo <thomas.bergo at gmail.com
>> >>        <mailto:thomas.bergo at gmail.com>
>> >>        <mailto:thomas.bergo at gmail.com <mailto:thomas.bergo at gmail.com
>> >__>>
>> >>             I'm also get this alert.
>> >>             Regard, Thomas
>> >>             tirsdag 29. oktober 2013 skrev Rolf Welde Skeie følgende:
>> >>                 Hi,
>> >>                 I'm getting 12V battery alerts ala:
>> >>                 "MP-0 PAALERT!!! 12V BATTERY CRITICAL (13.2V,
>> ref=14.7V)"
>> >>                 So the 1.5V hardcoded difference between charged and
>> >>        non-charged
>> >>                 state seems to be too low. The battery is working just
>> >>        fine and
>> >>                 has been tested without any issues, but seems to
>> >>        stabilize at
>> >>                 approx. 12.8V.
>> >>                 Is this a global issue; are others experiencing this as
>> >>        well?
>> >>                 If this is a issue only relevant to my car: would it
>> >>        make sense
>> >>                 to allow for controlling some of these kind of values
>> >>        through
>> >>                 parameters?
>> >>                 BTW, I believe the Think City module could be put in
>> the
>> >>                 production builds, it seems to be working fine.
>> >>                 Best regards
>> >>                 Rolf Welde Skeie
>> >>                 Solåsen 27, 5223 Nesttun, Norway
>> >>        +47 92403016 <tel:%2B47%2092403016> <tel:%2B47%2092403016> /
>> >>        rwskeie at gmail.com <mailto:rwskeie at gmail.com>
>> >>                 ___________________________________________________
>> >>                 OvmsDev mailing list
>> >>        OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>> >>        http://lists.teslaclub.hk/____mailman/listinfo/ovmsdev
>> >>        <http://lists.teslaclub.hk/__mailman/listinfo/ovmsdev>
>> >>        <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>>
>> >>        <mailto:OvmsDev at lists.__teslaclub.hk
>> >>        <mailto:OvmsDev at lists.teslaclub.hk>>
>> >>    Rolf Welde Skeie
>> >>    +47 92403016 <tel:%2B47%2092403016> / rwskeie at gmail.com
>> > Rolf Welde Skeie
>> > +47 92403016 / rwskeie at gmail.com
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131113/9008b3b6/attachment.htm>
