[Ovmsdev] 12V battery alerts
Håkon Markussen hakon.markussen at gmail.com
Thu Nov 14 00:28:29 HKT 2013
I have now rolled back locally the net.c to «car_12vline_ref - 15» and added
car_doors1bits.CarON = 0;
car_doors5bits.Charging12V = 0;
to vehicle_thinkcity.c when:
- discharge is not allowed AND charge is not enabled
In addition to car_doors5bits.Charging12V = 1;  when:
 - charge is enabled
 - End of Charge is detected AND plug is attached
Some quick tests gives positive result that no 12V Critical Alert is send.
I’ll keep you posted.
Br.
Håkon
13. nov. 2013 kl. 08:51 skrev Håkon Markussen <hakon.markussen at gmail.com>:
False 12V alerts disappeared when triggering alert from ref - 2,0V.
    // Trigger 12V alert if voltage <= ref - 1.5 V:
    if (!(can_minSOCnotified & CAN_MINSOC_ALERT_12V)
            && (car_12vline <= (car_12vline_ref - 20)))
      can_minSOCnotified |= CAN_MINSOC_ALERT_12V;
      net_req_notification(NET_
NOTIFY_12VLOW);
Br.
Håkon
2013/11/12 Håkon Markussen <hakon.markussen at gmail.com>
When setting Notifications (parameter #3) to "IP" or "SMSIP" I finally receive alerts - including Minimum SOC (feature #9) ;)
The 12V Critical Alert triggers quite often, even if my 12V-battery is new and in top condition.
I've measured that the car_12vline reports ~0,5V less than the real battery voltage, so I plan to change the file net.c (line 1458) from:
            && (car_12vline <= (car_12vline_ref - 15)))
      net_req_notification(NET_NOTIFY_12VLOW);
to:
and compile it to a local hex-build and test in on my Think City.
Keep you posted about the result.
Best regards.
Håkon
2013/10/30 Mark Webb-Johnson <mark at webb-johnson.net>
Can someone try it at 2.0V (rather than 1.5V) and see if it solves the false-alerts problem?
On 29 Oct, 2013, at 5:10 pm, Rolf Welde Skeie <rwskeie at gmail.com> wrote:
> Ok, it seems like a few have similar issues.
> The logic behind the calculations seems to be reasonable, it is the assumption that there is a 1.5V difference between charging/non-charging state which is not generally applicable.
> From my observations it seems like increasing this to 2.0V would take care of most mis-firing events.?..
> Disclaimer: I'm not an expert on batteries...
> Running on 2.5.5 experimental/TC
> Rolf
> On 10/29/2013 10:00 AM, Matt Beard OVMS wrote:
>> Yup, I also get this message and it would be great if it were working
>> properly, but it actually fires at 13.1V which is far too high.
>> Matt
>> On 29 October 2013 08:46, Rolf Welde Skeie <rwskeie at gmail.com
>> <mailto:rwskeie at gmail.com>> wrote:
>>    I have the following features set:
>>    #0=1, #8=1, #9=1, #15=1, all others =0.
>>    Can't remember which one made it work, but one of them did, my guess
>>    would be #9 :)
>>    Rolf
>>    On 10/29/2013 09:38 AM, Håkon Markussen wrote:
>>        I never get this alert.
>>        I have a Think City (as Rolf Skeie) and use the iOS-app.
>>        I have tested on both an exhausted aux-battery and on a brand new
>>        battery in perfect condition.
>>        Br.
>>        Håkon
>>        2013/10/29 Thomas Bergo <thomas.bergo at gmail.com
>>        <mailto:thomas.bergo at gmail.com>
>>        <mailto:thomas.bergo at gmail.com <mailto:thomas.bergo at gmail.com>__>>
>>             I'm also get this alert.
>>             Regard, Thomas
>>             tirsdag 29. oktober 2013 skrev Rolf Welde Skeie følgende:
>>                 Hi,
>>                 I'm getting 12V battery alerts ala:
>>                 "MP-0 PAALERT!!! 12V BATTERY CRITICAL (13.2V, ref=14.7V)"
>>                 So the 1.5V hardcoded difference between charged and
>>        non-charged
>>                 state seems to be too low. The battery is working just
>>        fine and
>>                 has been tested without any issues, but seems to
>>        stabilize at
>>                 approx. 12.8V.
>>                 Is this a global issue; are others experiencing this as
>>        well?
>>                 If this is a issue only relevant to my car: would it
>>        make sense
>>                 to allow for controlling some of these kind of values
>>        through
>>                 parameters?
>>                 BTW, I believe the Think City module could be put in the
>>                 production builds, it seems to be working fine.
>>                 Best regards
>>                 Rolf Welde Skeie
>>                 Solåsen 27, 5223 Nesttun, Norway
>>        +47 92403016 <tel:%2B47%2092403016> <tel:%2B47%2092403016> /
>>        rwskeie at gmail.com <mailto:rwskeie at gmail.com>
>>                 ___________________________________________________
>>                 OvmsDev mailing list
>>        OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>>        http://lists.teslaclub.hk/____mailman/listinfo/ovmsdev
>>        <http://lists.teslaclub.hk/__mailman/listinfo/ovmsdev>
>>        <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>>
>>        <mailto:OvmsDev at lists.__teslaclub.hk
>>        <mailto:OvmsDev at lists.teslaclub.hk>>
>>    Rolf Welde Skeie
>>    +47 92403016 <tel:%2B47%2092403016> / rwskeie at gmail.com
> Rolf Welde Skeie
> +47 92403016 / rwskeie at gmail.com
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131113/c328be8b/attachment.htm>
