[Ovmsdev] Can-re tool
support at nirvtek.com support at nirvtek.com
Sun Nov 3 19:08:46 HKT 2013
I tried CPAN.
common::sense installed, but EV fails with this:
EV.obj : error LNK2001: unresolved external symbol _MemoryBarrier
On Nov 3, 2013, at 2:42 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> The plugins directory is just for CAN-RE-TOOL plugins. Standard perl libraries should be installed in the system paths.
> Assuming you are using activestate perl, can you just use the cpan tool to install them? It is a bit of a kludge on windows (as no C compiler as standard), and much easier on Linux / OSX, but should still be possible (I think the way it works is activestate maintains a mirror of cpan binary builds).
> On 3 Nov, 2013, at 2:05 pm, support at nirvtek.com wrote:
>> Hi
>> I’ve put the .pm modules into the plugins directory. The script does an @INC with the plugins directory.
>> Not sure how to add it to the default library path of PERL. The environment variables for PERL don’t appear to exist/.
>> Thanks
>> Sharanga
>> On Nov 3, 2013, at 7:41 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>> Sharanga,
>>> How have you installed EV and Common::Sense?
>>> They need to be installed into the perl system on the box. It sounds like you may have put them in the plugins directory of CAN-RE-TOOL?
>>> On 1 Nov, 2013, at 10:36 pm, support at nirvtek.com wrote:
>>>> Hi
>>>> I don't know whether this is the right list for this.
>>>> I can't get the can-re tool to run on Windows. I downloaded EV.pm and common::sense, but it yields this:
>>>> common/sense.pm did not return a true value at ../plugins/EV.pm line 121, <DATA>
>>>> line 451.
>>>> BEGIN failed--compilation aborted at ../plugins/EV.pm line 121, <DATA> line 451.
>>>> Compilation failed in require at canretool.pl line 38, <DATA> line 451.
>>>> BEGIN failed--compilation aborted at canretool.pl line 38, <DATA> line 451.
>>>> !help
>>>> Thanks
>>>> Sharanga
>>>> Nirvtek
>>>> OvmsDev mailing list
