[Ovmsdev] Can-re tool
Mon Nov 4 10:06:00 HKT 2013
Not really sure how I can help with this one. The CAN-RE-TOOL (like ovms_server.pl) requires EV (and AnyEvent, etc) to be installed on the system.
I know of users running ovms_server.pl on Windows, so it must be possible. But, I am not a windows users so can't really help.
A google search doesn't show up anything relevant either.
On 3 Nov, 2013, at 7:08 pm, support at nirvtek.com wrote:
> I tried CPAN.
> common::sense installed, but EV fails with this:
> EV.obj : error LNK2001: unresolved external symbol _MemoryBarrier
> On Nov 3, 2013, at 2:42 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>> The plugins directory is just for CAN-RE-TOOL plugins. Standard perl libraries should be installed in the system paths.
>> Assuming you are using activestate perl, can you just use the cpan tool to install them? It is a bit of a kludge on windows (as no C compiler as standard), and much easier on Linux / OSX, but should still be possible (I think the way it works is activestate maintains a mirror of cpan binary builds).
>> On 3 Nov, 2013, at 2:05 pm, support at nirvtek.com wrote:
>>> Hi
>>> I’ve put the .pm modules into the plugins directory. The script does an @INC with the plugins directory.
>>> Not sure how to add it to the default library path of PERL. The environment variables for PERL don’t appear to exist/.
>>> Thanks
>>> Sharanga
>>> On Nov 3, 2013, at 7:41 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>>> Sharanga,
>>>> How have you installed EV and Common::Sense?
>>>> They need to be installed into the perl system on the box. It sounds like you may have put them in the plugins directory of CAN-RE-TOOL?
>>>> Regards, Mark.
>>>> On 1 Nov, 2013, at 10:36 pm, support at nirvtek.com wrote:
>>>>> Hi
>>>>> I don't know whether this is the right list for this.
>>>>> I can't get the can-re tool to run on Windows. I downloaded EV.pm and common::sense, but it yields this:
>>>>> common/sense.pm did not return a true value at ../plugins/EV.pm line 121, <DATA>
>>>>> line 451.
>>>>> BEGIN failed--compilation aborted at ../plugins/EV.pm line 121, <DATA> line 451.
>>>>> Compilation failed in require at canretool.pl line 38, <DATA> line 451.
>>>>> BEGIN failed--compilation aborted at canretool.pl line 38, <DATA> line 451.
>>>>> !help
>>>>> Thanks
>>>>> Sharanga
>>>>> Nirvtek
>>>>> OvmsDev mailing list
