[Ovmsdev] Fwd: [Open-Vehicle-Monitoring-System] Driven km and Charge done message (#105)
Fri May 3 18:53:23 HKT 2013
Mark, Michael,
for the Twizy I've been sending alerts on charge completion from the
beginning. That's my preference, but I also received no complaints from
other users up to now. If you're limited to SMS, this is also the only
sensible way IMO, you'd otherwise need to query the charge state
manually using the "STAT?" command.
So may be the configuration could be on the App side? The App could
check for the notification text.
I also send an additional optional alert on partial completion
(sufficient charge level = "topping off"), that can be set by the "CA"
command -- IMO quite useful and as well suitable as a standard function.
Am 03.05.2013 02:51, schrieb Mark Webb-Johnson:
> Michael (J),
> I merged this.
> I'm a unsure about the message when charge is done part. You have it
> set to alert whenever a charge completes (even if normally up to 100%
> SOC), which is not normally. We would usually only alert if the charge
> is interrupted.
> Michael B: What do you do for Twizy on this? Do we need a standard
> option that the user can set to be alerted whenever a charge is
> completed (no matter succeed / fail)?
> Begin forwarded message:
>> *From: *"Michael J." <notifications at github.com
>> <mailto:notifications at github.com>>
>> *Subject: **[Open-Vehicle-Monitoring-System] Driven km and Charge
>> done message (#105)*
>> *Date: *3 May, 2013 3:55:48 AM GMT+08:00
>> Add CAN ID with driven km on Battery for calc for expected km
>> Add Messagen when Charhe is done
>>         Commit Summary
>>   * Driven km and Charge done message
>>         File Changes
>>   * *M* vehicle/OVMS.X/net_msg.c
>>     <https://github.com/markwj/Open-Vehicle-Monitoring-System/pull/105/files#diff-0>
>>     (1)
>>   * *M* vehicle/OVMS.X/vehicle_voltampera.c
>>     <https://github.com/markwj/Open-Vehicle-Monitoring-System/pull/105/files#diff-1>
>>     (32)
>>         Patch Links:
>>   * https://github.com/markwj/Open-Vehicle-Monitoring-System/pull/105.patch
>>   * https://github.com/markwj/Open-Vehicle-Monitoring-System/pull/105.diff
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130503/ab7f0b39/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130503/ab7f0b39/attachment-0002.vcf>
