[Ovmsdev] Fwd: [Open-Vehicle-Monitoring-System] Driven km and Charge done message (#105)
Fri May 3 08:51:31 HKT 2013
Michael (J),
I merged this.
I'm a unsure about the message when charge is done part. You have it set to alert whenever a charge completes (even if normally up to 100% SOC), which is not normally. We would usually only alert if the charge is interrupted.
Michael B: What do you do for Twizy on this? Do we need a standard option that the user can set to be alerted whenever a charge is completed (no matter succeed / fail)?
Begin forwarded message:
> From: "Michael J." <notifications at github.com>
> Subject: [Open-Vehicle-Monitoring-System] Driven km and Charge done message (#105)
> Date: 3 May, 2013 3:55:48 AM GMT+08:00
> Add CAN ID with driven km on Battery for calc for expected km
> Add Messagen when Charhe is done
> Commit Summary
> File Changes
> M vehicle/OVMS.X/net_msg.c (1)
> M vehicle/OVMS.X/vehicle_voltampera.c (32)
> Patch Links:
> https://github.com/markwj/Open-Vehicle-Monitoring-System/pull/105.patch
> https://github.com/markwj/Open-Vehicle-Monitoring-System/pull/105.diff
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130503/956b0e12/attachment.htm>
