[Ovmsdev] v2.2.2
Thu Jan 17 11:29:03 HKT 2013
The idea of permanent links sounds great, but now I'm confused.
I just flashed my V1 Roadster module, and it comes up as version 1.5.1. Now
that I look more carefully, I see that all of the .hex files I grabbed from
my updated OVMS directory are dated 10/21/2012. For example,
vehicle/OVMS.X/dist/RT_V2_Experimental
Looking at the links in the tagged v2.2.2 folder, I just see four builds
(V1,V2)x(Experimental,Production). I expected to see builds for each
vehicle.
Or is V1 just for the Roadster and the V2 build dynamically figures out
which vehicle it's on?
    Tom
on 1/16/13 5:39 PM, Mark Webb-Johnson wrote:
> I think I may have a solution for this (going forward).
> If we use the git 'tags' feature, to tag each released firmware build, github
> will allow us to publish the tree at that time. For example, see:
> https://github.com/markwj/Open-Vehicle-Monitoring-System/tree/v2.2.2/vehicle/f
> irmware
> And an example link to the v2.2.2 V2 production firmware is:
> https://github.com/markwj/Open-Vehicle-Monitoring-System/raw/v2.2.2/vehicle/fi
> rmware/V2_production.hex
> That link is quite clean and should be stable going forward. It will just take
> some discipline to set things up correctly during a release:
> Build all firmware
> Copy the .hex files to the firmware folder
> Update the change log
> Commit
> Tag the commit
> push (--tags) to github
> Announce the new version
> What do people think? Sensible?
> On 15 Jan, 2013, at 8:38 AM, Mark Webb-Johnson wrote:
>> I think this approach is ok, and given github's approach probably the best
>> way.
>> I really wish that github had a 'files' repository (like sourceforge) that we
>> could put fixed (not revision controlled) files. Release, not development,
>> files. I tried to create symlinks (in the 'firmware' folder), but they don't
>> work (the symlink text file is just downloaded, not the thing it linked to),
>> and anyway that doesn't give us history.
>> I've got a git guru on staff here at work - I'll ask him for his advise.
>> On 15 Jan, 2013, at 5:49 AM, Tom Saxton wrote:
>>> That directory structure changes about as often as there are new official
>>> releases, as you can tell by all of the orphan build directories. Linking
>>> straight into the repository won't let me pick up new vehicles, and will
>>> break when vehicles go from "experimental" to "production" status.
>>> The release notes aren't in the repository (AFAIK), so I have to enter those
>>> links manually as well.
>>> Given that I have to manually update the page, I figure it's more reliable
>>> to ferret out the right versions for each vehicle and copy them to my site.
>>> This way, my page keeps working even if the repository changes, which means
>>> less work maintaining the page between releases (which is currently zero
>>> effort).
>>> Anyone who's really into getting the latest builds can just grab the files
>>> from the repository. My page is to support those who don't care enough to
>>> climb that learning curve.
>>>   Tom
>>> on 1/14/13 1:23 PM, Michael Balzer wrote:
>>>> Thanks, Tom!
>>>> Hm... to optimize the rollout, have you tried to link directly to the
>>>> repository files?
>>>> The links in vehicle/firmware don't work, but using the github file
>>>> browser I can get for example...
>>>> https://raw.github.com/markwj/Open-Vehicle-Monitoring-System/master/vehicle
>>>> /OV
>>>> MS.X/dist/V2_Experimental/production/OVMS.X.production.hex
>>>> I'm new to github, but that URL scheme looks like being designed as a
>>>> permanent link.
>>>> Regards,
>>>> Michael
>>>> Am 14.01.2013 21:13, schrieb Tom Saxton:
>>>>> The firmware update guide page now has version 2.2.2 builds up.
>>>>> http://www.idleloop.com/tesla/ovms/
>>>>>    Tom
>>>>> OvmsDev mailing list
