[Ovmsdev] v2.2.2
Thu Jan 17 11:53:55 HKT 2013
Tom,
For firmware v2.x builds, there are now just 4:
V1_experimental.hex V1 Hardware Module, experimental firmware
V1_production.hex V1 Hardware Module, production firmware
V2_experimental.hex V2 Hardware Module, experimental firmware
V2_production.hex V2 Hardware Module, production firmware
A single firmware supports multiple vehicle types (selectable at run-time based on parameter #14 (or the fourth argument to the "MODULE" SMS command).
It may be worth pointing out the following on the update page:
> For Tesla Roadster owners, once you upgrade firmware from v1 to v2, you will need to either:
> (a) SMS "MODULE" command again to include the fourth parameter vehicle type "TR", or
> (b) use the iOS App to set parameter #14 to "TR" (you can even do this in the App _before_ you upgrade).
> You will require this for the CAN bus stuff to work. We have updated the Tesla Roadster user guide to reflect this new parameter.
On 17 Jan, 2013, at 11:29 AM, Tom Saxton wrote:
> The idea of permanent links sounds great, but now I'm confused.
> I just flashed my V1 Roadster module, and it comes up as version 1.5.1. Now
> that I look more carefully, I see that all of the .hex files I grabbed from
> my updated OVMS directory are dated 10/21/2012. For example,
> vehicle/OVMS.X/dist/RT_V2_Experimental
> Looking at the links in the tagged v2.2.2 folder, I just see four builds
> (V1,V2)x(Experimental,Production). I expected to see builds for each
> vehicle.
> Or is V1 just for the Roadster and the V2 build dynamically figures out
> which vehicle it's on?
> Tom
> on 1/16/13 5:39 PM, Mark Webb-Johnson wrote:
>> I think I may have a solution for this (going forward).
>> If we use the git 'tags' feature, to tag each released firmware build, github
>> will allow us to publish the tree at that time. For example, see:
>> https://github.com/markwj/Open-Vehicle-Monitoring-System/tree/v2.2.2/vehicle/f
>> irmware
>> And an example link to the v2.2.2 V2 production firmware is:
>> https://github.com/markwj/Open-Vehicle-Monitoring-System/raw/v2.2.2/vehicle/fi
>> rmware/V2_production.hex
>> That link is quite clean and should be stable going forward. It will just take
>> some discipline to set things up correctly during a release:
>> Build all firmware
>> Copy the .hex files to the firmware folder
>> Update the change log
>> Commit
>> Tag the commit
>> push (--tags) to github
>> Announce the new version
>> What do people think? Sensible?
>> On 15 Jan, 2013, at 8:38 AM, Mark Webb-Johnson wrote:
>>> I think this approach is ok, and given github's approach probably the best
>>> way.
>>> I really wish that github had a 'files' repository (like sourceforge) that we
>>> could put fixed (not revision controlled) files. Release, not development,
>>> files. I tried to create symlinks (in the 'firmware' folder), but they don't
>>> work (the symlink text file is just downloaded, not the thing it linked to),
>>> and anyway that doesn't give us history.
>>> I've got a git guru on staff here at work - I'll ask him for his advise.
>>> On 15 Jan, 2013, at 5:49 AM, Tom Saxton wrote:
>>>> That directory structure changes about as often as there are new official
>>>> releases, as you can tell by all of the orphan build directories. Linking
>>>> straight into the repository won't let me pick up new vehicles, and will
>>>> break when vehicles go from "experimental" to "production" status.
>>>> The release notes aren't in the repository (AFAIK), so I have to enter those
>>>> links manually as well.
>>>> Given that I have to manually update the page, I figure it's more reliable
>>>> to ferret out the right versions for each vehicle and copy them to my site.
>>>> This way, my page keeps working even if the repository changes, which means
>>>> less work maintaining the page between releases (which is currently zero
>>>> effort).
>>>> Anyone who's really into getting the latest builds can just grab the files
>>>> from the repository. My page is to support those who don't care enough to
>>>> climb that learning curve.
>>>> Tom
>>>> on 1/14/13 1:23 PM, Michael Balzer wrote:
>>>>> Thanks, Tom!
>>>>> Hm... to optimize the rollout, have you tried to link directly to the
>>>>> repository files?
>>>>> The links in vehicle/firmware don't work, but using the github file
>>>>> browser I can get for example...
>>>>> https://raw.github.com/markwj/Open-Vehicle-Monitoring-System/master/vehicle
>>>>> /OV
>>>>> MS.X/dist/V2_Experimental/production/OVMS.X.production.hex
>>>>> I'm new to github, but that URL scheme looks like being designed as a
>>>>> permanent link.
>>>>> Regards,
>>>>> Michael
>>>>> Am 14.01.2013 21:13, schrieb Tom Saxton:
>>>>>> The firmware update guide page now has version 2.2.2 builds up.
>>>>>> http://www.idleloop.com/tesla/ovms/
>>>>>> Tom
>>>>>> OvmsDev mailing list
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130117/51049b1f/attachment-0001.html>
