[Ovmsdev] Volt/Ampera
mikeljo at mac.com
mikeljo at mac.com
Wed Feb 6 20:10:29 HKT 2013
Hi mark,
i am a little bit confused.
In ovms.h you define this:
extern unsigned char car_doors1;
typedef struct {
unsigned FrontLeftDoor:1;
unsigned FrontRightDoor:1;
unsigned ChargePort:1;
unsigned PilotSignal:1;
unsigned Charging:1;
unsigned :1;
unsigned HandBrake:1;
unsigned CarON:1;
} car_doors1bits_t;
#define car_doors1bits (*((car_doors1bits_t*)&car_doors1))
so you can use the struct (car_doors1bits_t) as integer "variable" car_doors1 and as single bit car_doors1bits and vice versa.
Then you use the integer in vehicle_voltampera.c: (only a few examples!)
car_doors1 |= 0x0c; // Set charge and pilot bits
and
car_doors1 |= 0x40; // PARK
car_doors1 &= ~0x80; // CAR OFF
witch bits is now what?
My understanding is that the MSB is "FrontLeftDoor" and the LSB is "CarON".
If i am right, than this is wrong: "car_doors1 &= ~0x80; // CAR OFF"
this will clear FrontLeftDoor.
And this is "partial" right: "car_doors1 |= 0x0c; // Set charge and pilot bits"
this will set Charging and the unnamed bit. But should set charging and PilotSignal. Then it must be 0x18
Can you or anybody else check?
I think it is better to use the bits direct. Like this: car_doors1bits.ChargePort = 1
Bye
Michael J.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130206/095e9036/attachment.html>
